ignition/electrical issue and tranny issue
Old 08 Jun 2018, 09:59 am
Unhappy ignition/electrical issue and tranny issue
I have a 2006 pt cruiser touring edition non turbo manual 5 speed with 135,000 miles. This car has done nothing but give me the worst headaches. But I'm a single mother with 5 kids and need a vehicle to work and take the kids to appointments so im stuck with it.
Ok, so my car is doing a couple weird things here and there. First thing is sometimes when I park the car and go to turn the ignition off and I remove the key from the ignition completely, the car stays running. I have to stall it out or press the clutch all the way down to the floor for it to shut down the engine.
My second problem is the gear shifter. It is hard to get the car into 3rd gear while driving at times. It is also hard to get it to engage for reverse. We have checked the shifter cables and they are snug (we recently replaced the white round piece that holds the cables in place). It doesn't happen every time I go to shift into 3rd but I have noticed a few different times when it was being more difficult than others.
One more question, a few years ago my ac wasn't cooling. It had randomly out of nowhere started blowing hot when I was about halfway to work. I ended up taking it into a shop and they charged the system and had me run to Autozone to get some type of relay or ac switch real fast. They was able to replace whatever the part was in a minute or 2 and it was under the hood. I think it cost me around $50 for the item. My question is does anyone have any idea what that could have been that they had me purchase? I can't find the receipt and I cant remember things so I don't recall.
I'd really appreciate any help I can get! I'd take it to a mechanic but I can't afford to. My brother has worked on cars a little bit so he's been helping me out as best as he can.
Thank you very much
Old 09 Jun 2018, 06:57 am
Default Re: ignition/electrical issue and tranny issue
I don't know about the shifting problem, so won't venture a guess. As for the ac part, sounds like it was either a relay or the pressure cut out switch. Most likely the switch but they don't usually cost much over $20. I guess it depends on where you got it.
Old 09 Jun 2018, 10:28 am
When you take the key out are the gauges still working on the Instrument Cluster?
Tags
ac question, electrical, ignition problems, manual transmission issue
Auto tranny issue now PTloser32805 Tech & Performance Forum 11 02 Nov 2017 04:43 pm
electrical issue? PaTurboCruiser General PT Cruiser Discussions 11 01 May 2017 10:51 am
Help!! I have an electrical issue Destroyer4 General PT Cruiser Discussions 8 19 Jun 2015 08:23 am
Electrical issue stormnormm Western PT Forum 1 01 Jun 2013 07:45 am
Electrical issue? DMod General PT Cruiser Discussions 38 23 Jan 2012 08:49 pm
