Same time occasional multiple lights issue - PT 2009
Like Tree2Likes
  • 1 Post By ptcruisersteve
  • 1 Post By denis90
Old 11 Jun 2018, 12:22 pm
Default Same time occasional multiple lights issue - PT 2009
Hi all,
Suddenly noticed the occasional turn signal issue - the light wasn't working and the tic was more frequent then usually.
Was thinking just to replace a bulb but when checked the rest of lights realized when the issue is on place following lights will not work as well:
- left back turn signal
- front right turn signal
- front right low beam
- left high beam
So the issue occasionally comes and goes, either everything is fine or the whole set of signals is failing.
Most likely it's not a steering wheel control leather because when reproduced it can also be observed using the remote to lock/unlock the car - turn signals won't work.
What can be the next research point?
Thank you,
Denys
Old 11 Jun 2018, 03:14 pm
Default Re: Same time occasional multiple lights issue - PT 2009
Originally Posted by denis90 View Post
Hi all,
Suddenly noticed the occasional turn signal issue - the lamp wasn't working and the tic was more frequent then usually.
Was thinking just to replace a bulb but when checked the rest of lights realized when the issue is on place following lights will not work:
- left high beam
So the issue occasionally comes and goes, either everything is fine or the whole set is failing.
Thank you,
Denys
What happens if you turn on the turn sigals first before using the remote locks?
Old 11 Jun 2018, 09:48 pm
Not sure if correctly got it - when I take a key out of ignition the turn signals stop operation.
When lock a car from outside with a key - only front left and rear right signals will blink.
Along with that when driving front right low beam and left high beam also stopped working.
Old 11 Jun 2018, 10:01 pm
Flashing and all exterior illumination is controlled by the TIPM. A short to ground or voltage on the circuit will set a code.
Some possible codes for the turn signals would be:
B163B - Front Left Turn Control Circuit Low
B163C - Front Left Turn Control Circuit High
B163F - Front Right Turn Control Circuit Low
B1640 - Front Right Turn Control Circuit High
B1643 - Rear Left Turn Control Circuit Low
B1644 - Rear Left Turn Control Circuit High
B1647 - Rear Right Turn Control Circuit Low
B1648 - Rear Right Turn Control Circuit High
The circuits will need to be tested for a short to ground, short to voltage or an open circuit. An open circuit means that there is no continuity between the connector at the TIPM and the suspect lamp location. You may need a long jumper wire to perform these tests.
The driver circuit is on pin 1 at the bulb location.
TIPM locations are listed below:
Front left TIPM location is C4, pin 1.
Front right TIPM location is C4, pin 2.
Rear left TIPM location is C3, pin 4.
Rear right TIPM location is C3, pin 6.
If all wiring checks out fine and there are no shorts to ground, voltage or open circuits, then the TIPM drivers are possibly bad and the TIPM might need to be replaced.
I would suggest first checking the group of ground wires going to the drivers inner fender. They get corroded and start loosing contact.
denis90 likes this.
Old 16 Jun 2018, 09:38 am
Thank you Steve!
Alright, the issue is solved by replacing the TIPM. Fix cost - $80 and a little of time.
Frankly I didn't find a way to read error codes with my scanner, was a bit lazy to get to the front light wires through the wheels access and also was suspecting TIPM because of the the strange combination of errors.
So I went on e-bay, found a similar module for $80 with delivery and 60 days return, checked several sources on internet how to make different kinds of "resets" to make TIPM adapted to car and ordered a module.
I had a "56049719AR" module, received a "56049719AN" one.
Dorman says they are interchangable:
https://www.dormanproducts.com/p-508...rol%2520Module
"Resets" I made:
1) take the battery out and short cut + and - terminal to drain the capacitors in car
2) with battery now - on newly installed TIPM turn the key to first or second position and wait for 20 seconds to get it auto-configured.
That's it.
Got a new feature - car now makes a short horn when I lock it with remote.
Denys
Do the lights stay on all the time? rustymich Tech & Performance Forum 5 01 Feb 2017 07:37 pm
Brake lights and amber turn signal lights come on at same time Mikeecruiser Tech & Performance Forum 4 11 Nov 2016 04:23 pm
Is it time to give up? Constant P0344 issue shortchica Tech & Performance Forum 4 19 Jul 2016 09:55 pm
Multiple Sensor Error Lights Flashing ADKing Tech & Performance Forum 4 28 May 2014 01:29 pm
2009 Base PT Cruiser Cooling Fan Issue donsr1964 General PT Cruiser Discussions 2 02 Apr 2014 03:01 pm
