Transmission interchange compatability
Like Tree4Likes
  • 1 Post By 03pennythept
  • 3 Post By 03pennythept
Old 11 Jun 2018, 11:44 pm
Default Transmission interchange compatability
Hey guys,
So I have a 2003 PT Limited. I still have the factory auto trans in it. I believe per the dealer- its a 41TE. I recently took it out and hand it "rebuilt". The last time it was rebuilt, it was 37,000 Miles before this rebuild.
The guy who rebuilt the trans is a class A psycho. The front wheels took a lot of effort passed idle to get to move. After putting it in reverse, it took a lot of effort and you heard a lot noise, it moved with a lot of pedal throw. Then, we heard a clunk, and the reverse gear went out. We have not dropped the pan, however when I spoke to the builder on the phone, he alleged it was some coil pack/selector switch that was bad and not allowing enough pressure for the oil to move through the gears. He was supposed to fix it, but he freaked out on the phone after I asked him for a time frame, now refuses to fix it or refund the money.
I know of a yard that has a few good cruisers in it. One is a 2008 and a 2010. Will the transmissions work in the 2003? Any years that I should look for? Are there any differences or improvements that would benefit this change over?
Thanks for the help guys!!!
Old 12 Jun 2018, 02:36 am
Default Re: Transmission interchange compatability
Transaxles from 2007 thru 2010 will NOT work in your car. 2001 thru 2002 had a separate [stand alone] trans control module, I don't know if they will interchange with your car.
Old 12 Jun 2018, 12:08 pm
So, basically I'm screwed...
Can I use a 2003-2006 trans then? Or is it 04-06 only.... 2001 and 2002, and 2007-2010; leaving the 2003 an oddman out year ?
Handy_Cruiser likes this.
Old 12 Jun 2018, 05:34 pm
Handy_Cruiser's Avatar
Originally Posted by 03pennythept View Post
Hey guys,
Any 41TE or 40TE from a 2001 thru 2006 PT will work. You don't have to worry about the separate TCM on the 2001/2002 PT's, the tranny is the same. The Autostick in the GT's doesn't make a difference either. Again, same 41TE tranny. But in 2007 Chrysler added variable line pressure (VLP) and there's an extra control plugin.
In general the 41TE was used in the 2001/2002 PT's and in all turbo models. The rest usually got a 40TE which is the same tranny but with a lighter clutch pack. Either will work fine in a non-turbo PT.
Old 24 Jun 2018, 11:54 pm
Transaxles from 2001-2005 would work.... 2006+ had extra electrical connectors.
I found a good used 2003 TA and installed it with new axle seals, filter, pan RTV, and used ATF 4+ synthetic from supertech. works wonderful!!!!
Compatability for Swapping White2007 Tech & Performance Forum 3 11 Nov 2016 07:40 am
Turbocharger Compatability rfroaden General Turbo Discussions 4 02 Dec 2013 07:50 pm
Manual transmission interchange? htchevy2 Tech & Performance Forum 0 04 Apr 2011 11:10 pm
compatability masterdan Tech & Performance Forum 0 04 Jan 2011 08:50 am
CD Changer Compatability Utah_Aviator General PT Cruiser Discussions 6 18 May 2006 09:06 pm
