Reading low oil pressure on gauge
  • 1 Post By ptcruisersteve
Old 19 Jun 2018, 03:23 pm
Default Reading low oil pressure on gauge
2003 PT Turbo, 140k miles, reading 5 psi in idle, driving 15-30 psi. What is the normal pressure for these motors to run? Could my turbo oil feed lines be coked causing the drop? Thanks in advance.
Old 19 Jun 2018, 03:52 pm
Default Re: Reading low oil pressure on gauge
readings should be:
at curb idle: 4 psi minimum
3000 rpm 25 to 80 psi
What weight oil are you using?
Old 19 Jun 2018, 04:08 pm
Handy_Cruiser's Avatar
The turbo line alone should not do this. The best 1st step is to install a temporary aftermarket oil gauge to see if you get the same number. However, an easier first step might be to simply do an oil change with 5W30 and a new filter.
If that doesn't fix it, consider either the temporary oil gauge to just change out the factory oil sending unit. The cost and the installation difficulty of installing a temporary gauge or just replacing the sending unit are usually about the same. And with either you will get a degree of conformation for true low oil pressure if it doesn't work. But again, try the oil change first.
Old 19 Jun 2018, 05:04 pm
Is the low oil pressure issue on the engine that you had the bearing issues?
Handy_Cruiser likes this.
Old 19 Jun 2018, 07:08 pm
Good catch, Steve.
If this is the same car, we may have already covered some of this ground. For everyone else, here's a link to that thread:
Possible blown motor help!!!
Old 20 Jun 2018, 01:20 am
_PTGT03's Avatar
Idle oil pressure for my 2003 GT is 60-80 psi and highway pressure is usually 80-100 . Cold start engine oil pressure is always over 100 psi at idle. I'm using AMS oil Signature series 10W30 with a WIX filter.
Either your gauge is out of calibration, or you're taking the measurement in the wrong place.
I removed the oil pressure switch from its existing location and installed the oil pressure sender in its place.
Old 20 Jun 2018, 08:07 am
Fk5 Fk5 is offline
I'd lean towards your having these problems. That sounds crazy high.
2003 GT 5 speed
162,000 miles
Old 21 Jun 2018, 12:18 am
_PTGT03's Avatar
No, it's correct. Specification oil pressure at 3,000 RPM is 25-80 PSI .
Specification oil pressure at idle speed however is 4psi, but I'm doubting that as accurate, I've never seen my oil pressure at idle lower than 40.
Oil pressure gauge Pippov General Turbo Discussions 3 06 May 2017 02:03 pm
Tire Pressure Monitor Light - false reading? zeontestpilot General PT Cruiser Discussions 12 09 Sep 2014 12:18 am
TEMP GAUGE READING TO LOW Busted_PT Tech & Performance Forum 52 22 Aug 2013 08:34 pm
Reading for A/F Gauge DaShado Tech & Performance Forum 3 23 Mar 2007 11:13 pm
oil pressure gauge GTPT Turbo Performance 6 30 Sep 2003 06:03 pm
