Engine just shut down on me
Old 21 Jun 2018, 01:29 pm
Default Engine just shut down on me
I was on the highway. Engine shut off on me.
I though for a second the engine was seized up. Pulled over, it turns over but wonít start.
Codes 1684. 0320. 1391
Timing belt looked intact
Damn this sucks Iím far from home
Old 21 Jun 2018, 02:42 pm
Default Re: Engine just shut down on me
I though for a second the engine was seized up. Pulled over, it turns over but won’t start.
Damn this sucks I’m far from home
Did you try unplugging the battery cable wait 2 min and reconnect?
I try this if I dont have the necessary tools or parts with me as long as it wont damage anything if I am on the side of the road or hwy.
P0320 - No Crank Reference Signal to PCM
Possible Causes:
1. Crankshaft Sensor signal circuit open or grounded
2. Crankshaft Sensor VREF circuit open or grounded
3. Tone wheel or flex plate damaged or erratic CKP Sensor signals
4. Crankshaft Sensor is damaged or has failed
5. PCM has failed
P1684 Battery Has Been Disconnected
Possible Causes:
1. Quick Learn procedure was performed with scan tool
2. TCM battery direct (B+) circuit is open or disconnected
3. TCM power ground circuit is open
4. PCM/TCM was disconnected or it has been replaced
P1391 Camshaft or Crankshaft Signal Intermittent Condition
Possible causes:
1. Timing belt or chain stretched or jumped
2. Faulty Camshaft Position Sensor
3. Camshaft Position Sensor harness is open or shorted
4. Camshaft Position Sensor circuit poor electrical connection.
I would suggest checking to see if the wire harness is rubbing on the half shaft or rubbing against the chassis.
Old 21 Jun 2018, 05:31 pm
I got towed to an autozone. I think itís the fuel pump. I donít hear it coming on. Checked fuse and relay. I pushed the shreder valve in on the fuel rail. Very little fuel came out. A few drops. Iím picking up a fuel pump now. But I donít have tools with me to change it.
Old 21 Jun 2018, 06:27 pm
I have no clue on this but, could one of your faults tell the PCM to kill power to your fuel pump? I'd look at the systems the dtc's are steering you towards before replacing anything. At the very least throw a cam sensor in it. If no luck, box it up and return.
Old 21 Jun 2018, 06:40 pm
When the camshaft sensor failed on my Pt Cruisers I just unplug and plug the battery cable and I got the Pt Cruisers home to replace the camshaft sensor. Might not work every time but it did it each time the sensor failed on me.
What year is your Pt Cruiser?
Old 21 Jun 2018, 07:09 pm
2001. But I replaced the sensor. I had an extra one in my car did not solve it
Getting fuel pump changed out now
Old 21 Jun 2018, 07:26 pm
LionPT's Avatar
Did you check the harness above the passenger side half shaft..??
Old 21 Jun 2018, 07:32 pm
The computer has to see signals from the sensors before it would turn on the automatic shutdown relay which powers the ignition coil(s), injectors, and fuel pump.
After replacing the camshaft sensor what diagnostic trouble codes are being triggered? This is important to keep from replacing unnecessary components.
Did you actually spray some starter fluid in the throttle body to see if the engine starts to run?
Old 21 Jun 2018, 07:48 pm
sanatanadharma's Avatar
The fuses!
Does no one check the fuses?
One fuse can cause the symptom
Think of the fuses like children
Look to them first
Does no one think of the children?
VsandFords likes this.
Old 21 Jun 2018, 07:50 pm
Loose the ground on the pump and it will quit.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Engine won't shut off!!! tikitoride General PT Cruiser Discussions 8 21 Nov 2016 02:50 am
Engine shut off while driving. No codes Twoscoops2 Tech & Performance Forum 7 21 Jan 2014 07:24 pm
pt blowing fuse to shut off engine ? bruinspt Tech & Performance Forum 2 23 Jun 2009 10:32 pm
Engine Shut Off, Will Not Restart Stevearino Tech & Performance Forum 37 18 Oct 2007 11:55 am
The noise engine makes when you shut off? stirfry Tech & Performance Forum 7 26 Apr 2004 06:50 pm
