Well guys I know I can probaly trust you guys more than any one else so here it goes. About a 2 weeks ago I noticed that my Airbag light when on. I searched for codes, Nothing. I hooked up a Code reader, nothing. So I said it should go away. Then Last week, My engine light comes on. I check all fluids, oil/filter change, air filter, clean injectors, new wires, plugs, coil. Still light on, check for codes, Nothing once again. I already spent alot of money so do you guys have any suggestions ? |
I recommend a professional scan tool.
A consumer level scanner will not access SRS, ABS, BCM, TCM, and many other protocols. If the light is on, you have codes to read. Simply throwing parts at it is not the right method of diagnosis. My $4200 OTC Genisys or even an updated Snap-on MT2500 will be able to see the datastream that has set the codes in history. |
Well I bought a code reader, and the only code it spit out was P0420
420 The catalyst seems inefficient (#1). Im thinking its either the oxygen sensor Bad fuel gas cap Any other suggestions.
!$NEO$! 2001 PT Cruizer Limited Edition, Intake vortex, Cold Air intake, Headers, Cherry Bomb with dual lake pipes,Gold Line Lowering Springs, Old school Bomb Rear Lights, Infinity Head unit, 4 TV\'s, Playstation, DVD, 2 MTX mono Amps, 1500 Watts Each, 3 12\'inch Infinity Kappas. |
P0420 is only for the downstream O2 sensor.
A gas cap would trip an EVAP leak detection code. Bad gas would trip the upstream O2 sensor as well. You need to watch the datastream to verify the sensor output. It could be an electrical intermittent, PCM fault, sensor performance, or converter malfunction. You CAN'T find the cause without more diagnosis. Fixing the symptom won't cure the cause. There are still SRS codes to read for the airbags. A consumer grade scanner can't access them. |
Well I thank you guys for helping me, My friend has that 2 Grand snap on code reader, hopefully he can trouble shoot it
| trouble with fog light switch? | twins4me | General PT Cruiser Discussions | 16 | 04 Nov 2009 05:06 pm |
| Trouble with PTE Site | tpscruiser | Non-PT Discussions | 4 | 04 Jun 2005 04:06 pm |
| Trouble shifting into 3rd gear on 5-speed GT | purplept | General Turbo Discussions | 23 | 28 May 2004 12:00 pm |
| trouble code | Paw | General Turbo Discussions | 21 | 20 Oct 2003 11:46 pm |
| Anyone have trouble with this forum? | Retro | General PT Cruiser Discussions | 3 | 20 Oct 2003 12:55 am |
