Use anti-sieze compound on spark plug? Or not?
Like Tree3Likes
  • 1 Post By Tuggajb
  • 1 Post By Carl48
  • 1 Post By NitroPT
Old 23 Jun 2018, 03:31 pm
Default Use anti-sieze compound on spark plug? Or not?
This is for a 2005 non-turbocharged PT Cruiser.
The Haynes Repair guide for this vehicle recommends using an anti-seize compound on the threads of the spark plug when installing.
The official Service Guide for this vehicle makes no recommendation whatsoever either prescribing or proscribing the use of an anti-seize compound.
What does everybody here think of this? I am planning on using Champion 7570 spark plugs.
Old 23 Jun 2018, 04:16 pm
Default Re: Use anti-sieze compound on spark plug? Or not?
I use it on all my spark plugs. Since it is an aluminum head it will prevent galling and make the next change easier. Just my opinion.
Old 23 Jun 2018, 04:37 pm
Very good opinion
All ways use
ptsilver likes this.
Old 23 Jun 2018, 05:56 pm
Use it sparingly. Do not glob it on. Avoid fouling out the plug.
Old 23 Jun 2018, 07:12 pm
Anti seize is very seldom recomend in any Factory Service Manual...because if you use to much it can cause continuity problems. Use only sparingly (as another member described) what ever you define that is.
I always use it on the spark plugs threads and have for decades and never had a problem with cross threading or continuity. I also clean the spark plug threads with either carb or brake clean and properly torques the spark plug.
Old 24 Jun 2018, 12:07 pm
I always use anti-seize on the plugs. It really makes a difference when you have to change them again and you don't pull out the treads along with the plug.
Spark Plug (Coil-On-Plug) Boots at RockAuto.com! RockAuto Vendors & Buyers Forum 7 23 Jan 2017 03:17 pm
Spark Plug ? veracruise Tech & Performance Forum 8 19 Dec 2011 12:39 am
Anti-Seize Compound on PCV Valve? ptbeard Tech & Performance Forum 9 07 Jun 2009 09:15 pm
Spark pulgs and spark plug wires? balvarez814 Tech & Performance Forum 1 13 Aug 2008 08:16 pm
oe spark plug gap? thundercat2 Tech & Performance Forum 3 20 Jun 2008 10:22 am
