Failed smog
Old 02 Jul 2018, 03:47 pm
Default Failed smog
Obd2 mon itors not ready.. Oxygen sensor/catalyist...No codes or check engine light...Wtf??? Help...Tried procedures for setting readiness monitors by driving car as directed..Any ideas???
first 4 cylinder,it sure aint no 8....2004 2.4 base pt 5 speed manual.live wires,screeming demon coil, stage 1jet chip,strut tower bar,airraid setup..nothing fancy...NO TURBO
Old 02 Jul 2018, 06:21 pm
Default Re: Failed smog
What procedure did you try to clear your monitors?
Have you done anything recently to the Pt Cruiser?
Old 02 Jul 2018, 06:24 pm
driving normaly take about 45-50 miles
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 02 Jul 2018, 06:28 pm
Think there might be tsb on a software update for your year model. I'll try to track it down.
Old 02 Jul 2018, 06:40 pm
Sorry, I was thinking of technical service bulletin number 18-112-16, but its for 2003, 5sp, turbo. I see you are 2004, 5sp, na.
Old 02 Jul 2018, 09:21 pm
Sometimes it just takes a long time and multiple trips.
Make sure you do a long drive from a cold start. Then let it cool down completely. Then drive it up to temp again and check the monitors. This has worked for me before. But sometimes it took days for them complete for some reason.
Autozone might be able to check them for you before trying the smog test again.
03 Turbo AutoStick
107K
Cranny
Old 03 Jul 2018, 01:42 am
It usually takes 3 'good trips' to make the monitors ready. A 'good trip' is starting with a cool engine and driving about 10 minutes. More info is out there on the web.
Old 03 Jul 2018, 01:53 am
This Chrysler Drive Cycle might help.
https://img.neons.org/archives/chrysler_drive_cycle.pdf
04 Pt Gt won't smog! xxxhemi General PT Cruiser Discussions 18 02 Aug 2017 02:37 pm
Failed Smog Test - Need Help "Re-cycling" Computer myjeephatesme Tech & Performance Forum 20 23 Dec 2013 05:14 am
Failed CA smog test PTMikeyM Tech & Performance Forum 51 08 Nov 2013 06:30 pm
Smog Question PTColossus General PT Cruiser Discussions 14 11 Jul 2013 06:35 pm
Has anyone familed smog? R_I_PT Tech & Performance Forum 0 22 Nov 2011 06:43 pm
