Limp mode today
  • 1 Post By siamese_retriever
Old 11 Jul 2018, 03:41 pm
Default Limp mode today
Well, this was a new thing for me! My 2007 went into limp mode today, on the interstate. I have a cheap OBD in the car, and it gave me three codes - P0700, P0882, and C2500. I am hoping to get some tips on what I can check in the next hour or so before my wife picks me up to give me a ride home. Looks like it is an electrical issue from my (very) brief research. I don't have my meter in the car, but she is bringing that along with her. Side note - MIL and the airbag lights came on when this happened, and are still on.
Thanks!
Old 11 Jul 2018, 06:06 pm
Handy_Cruiser's Avatar
Default Re: Limp mode today
You may need to inspect for a damaged wiring harness. Remove the air filter housing and check every wire you can find. Unplug the four plugs from the PCM, then clean them and plug them back in.
Old 11 Jul 2018, 06:51 pm
Thanks!! I did another forum search and used a different code from today that time, and found a thread with a whole lot of information. Dealing with this might be more than I have time & patience for right now, so I may look for a shop that can handle electrical gremlins. The ground wires next to the battery _looked_ okay, but I am going to look for contact cleaner and check them a little closer. I am also going to see if I can find the PCM. When this happened, I thought the transmission was shot. I am somewhat relieved that it is more likely an electrical issue.
Handy_Cruiser likes this.
Old 12 Jul 2018, 08:50 am
Thanks!
Does your OBD tell you what the C2500 is for?
Limp Mode? Bentron General PT Cruiser Discussions 23 21 Jun 2016 10:54 am
Limp Mode....? CluelessKate Tech & Performance Forum 6 11 May 2016 11:51 am
limp mode questions... sugarplumscruiser Tech & Performance Forum 6 03 Aug 2015 09:21 pm
Transmission going into Limp Mode KariJ Tech & Performance Forum 1 22 Jul 2014 04:02 pm
help..limp mode ivynthemnts758 Tech & Performance Forum 2 09 Sep 2010 08:44 am
