Brake peddle intermittently soft! Where to buy parts!
  • 1 Post By My02RedRide
Old 16 Jul 2018, 07:20 pm
Default Brake peddle intermittently soft! Where to buy parts!
2003 PT Base.
My break peddle is intermittently soft. Sometimes it's fine and other times
flooring it with slow breaking.
I'm presuming that since I cannot see leaks on any of the break lines on the four wheels that the problem is the Brake Master Cylinder .
Where is the best place to order a replacement?
Also, is there any reason to think the break booster would be at fault and how to test it?
Old 16 Jul 2018, 07:40 pm
RickinPA's Avatar
Default Re: Brake peddle intermittently soft! Where to buy parts!
Sounds like classic failure of the seals in the master cylinder. The symptom is the brake pedal drifts to the floor when the brakes are applied. The cause is failure of the piston seal, the brake fluid leaks past the seal to the backside of the cylinder. When you let up on the brake pedal, the cylinder refills with the brake fluid, there's no apparent leak on the outside of the master cylinder.
Get it fixed soon, brakes are (obviously) not something to delay repairs on.
The fix is a new master cylinder. I can't advise a make, I've only replaced a couple on cars over the years. I think I just got a new master cylinder from the local auto parts store.
I seem to remember a bench bleeding procedure to prepare the master cylinder for installation, then bleeding air out at the master cylinder connection fittings after installation. It's generally an easy job. Follow the service manual for installation.
Old 16 Jul 2018, 08:26 pm
UptownSport's Avatar
The master cylinder used to come with a bench bleeding kit.
Try Rockauto. They are members and post a discount code here.
Huuuge selection, and a lot of information on each choice.
Very inexpensive, too.
Old 16 Jul 2018, 08:32 pm
I'm confused by their part options:
https://www.rockauto.com/en/catalog/...+cylinder,1836
Old 17 Jul 2018, 03:59 pm
My02RedRide's Avatar
Find a U-Pull bone yard... Got one for the '02 because of the proportioning valve (1) was bad causing right rear to over pressure / hold pressure and over heat. Paid like $15 for the master complete with proport valves. Washed and flushed it inside with fresh brake fluid, installed it and bled the whole system till clean was coming out each wheel bleed and no problems. Pretty easy install actually. Wife did the pump pump pump hold bleeding.
wingman55 likes this.
2002 PT 4 door Inferno Red
2008 PT Convertible Bright Silver
Old 15 Aug 2018, 12:40 am
Finally replaced it today. Took 3 hours including bleeding and flushing the brakes lines. Not difficult; it just took time.
Old 15 Aug 2018, 12:46 am
The plastic/rubber cap on the driver's side bleeder screw broke apart. Is there a particular size I can order off amazon? Or an alternative I can get at the Home Depot?
Suspension and Brake Parts NightWing Classifieds: For Sale/Trade 0 02 Aug 2016 01:58 pm
Soft top ECU? manorgates PT Cruiser Convertible Forum 4 08 Apr 2014 07:26 pm
pt stalls when i step on the gas peddle california Tech & Performance Forum 8 21 Oct 2013 08:48 pm
Engine wants to die when I give it peddle. marcopono Turbo Performance 12 07 Dec 2011 01:09 pm
Soft Top DaShado The Detail Shop 0 01 Apr 2006 12:24 am
