2007 PT cooling fan problem
  • 1 Post By pt06
Old 19 Jul 2018, 11:10 pm
Default 2007 PT cooling fan problem
The radiator fan on my 07 PT Cruiser won't turn on. I have a new fan,tipm, connections good. Fan powers up when power is applied. Dose the coolant temp. Sensor signal the ecm when fan needs to run? Or is it an emmisions sensor?
Old 20 Jul 2018, 01:08 am
Default Re: 2007 PT cooling fan problem
Does the engine light come on? If so what codes are being triggered?
Usually you would get a code for the coolant temperature sensor if it was not working properly.
With the engine cold, have you tried starting the engine, turning on the A/C to see if the radiator fan automatically comes on almost immediately?
Did the new radiator fan come with new radiator fan relays?
Did you check the group of ground wires going to the drivers side inner fender?
Old 20 Jul 2018, 02:43 am
The coolant temp sensor sends a signal to the engine computer. The computer tells the TIPM when to turn on the relay coils. There is a fuse under the TIPM cover [#15 fuse -- 50 amp.]. It powers the fan relays.
Old 20 Jul 2018, 01:17 pm
P0481 - High Speed Fan Relay Control Circuit:
Possible Causes:
Fused (B+) Circuits
Ground Circuit
High Speed Rad Fan Control Circuit Shorted To Battery Voltage
High Speed Rad Fan Control Circuit Open
High Speed Rad Fan Control Circuit Shorted To Ground
Radiator Cooling Fan Module
Totally Integrated Power Module
If the fuse is blown make sure you find out what caused it to blow.
2007 Cooling Fan Question bean1957 General PT Cruiser Discussions 24 24 May 2018 05:27 pm
Here we go again! Cooling problem fabreezai Tech & Performance Forum 7 27 Apr 2016 06:22 am
cooling problem johnbartlett1 General PT Cruiser Discussions 6 24 Jun 2015 02:00 pm
PT cruiser 2007 engine cooling fan fuse blowing Tracyevans General PT Cruiser Discussions 0 30 Apr 2012 09:51 pm
Cooling problem... Coop General PT Cruiser Discussions 19 03 Sep 2011 11:57 am
