Question about p0320 code
Old 27 Jul 2018, 12:45 pm
Default Question about p0320 code
So my question is what sensor is it? I have 2001 PT cruiser le 148xxx miles. It died while i was driving. After about 20 minutes it would again. A friend got me the cam and crank shaft sensor. But it was after market parts. So it died and would not start again. Took a chance put the old parts back on and now it will start. Lol Just scared to drive it. Don't want to be sitting on the side of the road again. Going to replace them again with the right parts. Would like to know which one it is. The codes it is giving is p0320.
Old 27 Jul 2018, 12:53 pm
Default Re: Question about p0320 code
P0320 - No Crank Reference Signal to PCM
Possible Causes:
1. Crankshaft Sensor signal circuit open or grounded
2. Crankshaft Sensor VREF circuit open or grounded
3. Tone wheel or flex plate damaged or erratic CKP Sensor signals
4. Crankshaft Sensor is damaged or has failed
5. PCM has failed
Recommend checking the wiring going to the Crankshaft sensor before checking the Crankshaft sensor.
Old 27 Jul 2018, 01:09 pm
I have read post about the wires going to it. And i did have a wire that was messed up. That was the first thing i did. I fixed it and it is tied up out of the danger zone now lol. But then the code came back that is when i replaced the sensors.
P0320 P1684 codes WingMD General PT Cruiser Discussions 9 05 Oct 2016 04:55 pm
2001 pt with p0320 code limechallenger Tech & Performance Forum 21 14 Jan 2015 03:33 pm
Help me please! P1684, P0117 & P0320 bananabond Tech & Performance Forum 12 09 Apr 2013 07:15 pm
P0320 tjkilcup Tech & Performance Forum 12 23 Dec 2011 09:00 pm
Error Codes P1388 and P0320 baldbryn Tech & Performance Forum 1 30 Oct 2011 05:04 pm
