HELP! Won't start, buzzing sound when trying to start
Like Tree4Likes
Old 29 Jul 2018, 11:09 pm
Default HELP! Won't start, buzzing sound when trying to start
I have a 2004 PT Cruiser Limited Ed Turbo, about 140,000 miles on it.
It ran just fine earlier today, never had problems with it starting before.
I parked it at the library, went in for several hours, came out and it wouldn't start.
At first it tried to turn over, but then it switched to a "buzzing" sound.
I tried to have someone jump-start the car, but it didn't work. It would crank but not start. Then after trying a couple times it started buzzing again.
There was some whitish powder on the battery terminals, so I cleaned them off but it still wouldn't start.
So I left it for about 30 minutes. Came back to try and start it, it tried to turn over but wouldn't. Then after trying a couple times it started the buzzing again.
I'm hoping it's just a bad battery, because I only have a couple hundred $ in the bank right now and I'm currently unemployed.
Old 30 Jul 2018, 02:46 am
_PTGT03's Avatar
Default Re: HELP! Won't start, buzzing sound when trying to start
i would start with a battery voltage and load test.
second, with low money in the bank perhaps its a good idea to use public transit or bike around until you have enough energy money to cover unexpected car repairs in the future. the bus is a lot more reliable than a 14 year old used american car with lots of miles.
once you know if the battery is good or not, a cheap option is a good used battery from the auto wreckers of the exact same size. after the battery is replaced, examine the charging voltage to make sure it's giving at least 13.5 volts at idle.
i find that i have to leave my PT on a battery tender if I don't start it for about a week at a time.
Old 30 Jul 2018, 06:58 am
I agree about getting the battery checked out. I'd also recommend that you check the battery cables. Check the positive cable all the way to the starter and the grounds for corrosion. Remove the air box and check the battery grounds on the inside of the drivers fender. You can do a search here and see what I'm referring to.
Old 30 Jul 2018, 10:35 am
First I would suggest checking for codes if the engine light is on.
If engine light is not on take the top lids off of the battery and see if one of the cells is low on fluid.
As others have posted check the battery voltage as you are cranking it to make sure you are above 10.5 volts if you have a voltmeter.
If no engine light I would try disconnecting the ground cable from the battery and connect it back on.
Post what you find out.
Old 31 Jul 2018, 10:49 am
Fk5 Fk5 is offline
You can still do this? I don't think most of the batteries I have put in my PT even have caps to remove. I remember that it used to be a thing and even some of the older "maintenance free" batteries still had caps, but I am not sure this is possible with the KMart special in my car.
ptprice likes this.
2003 GT 5 speed
162,000 miles
Old 31 Jul 2018, 03:15 pm
PTpreacher's Avatar
My PT was doing that and I took the batt. cables off and took a knife and really cut
back the crust formed on the posts and cleaned inside the cable the same way. Then if
the batt. is dead try jumping the car. it worked for me! PTpreacher
Old 31 Jul 2018, 08:29 pm
The new batteries still have caps. Usually 2. The label hides them.
Maintenance free batteries just means we don't want you to mess with it so you have to buy a battery. When the warranty is up on my batteries I put the caps and check the level.
Old 01 Aug 2018, 12:47 am
LionPT's Avatar
With a "buzzing sound", I would check the starter solenoid. JMO
Old 01 Aug 2018, 02:37 pm
I was able to finish a commission and will have about $1000 in my account tomorrow, so that will definitely help.
I didn't look into the battery yet, but will later today.
I did try to clean off the terminals with a wire brush and asked someone to help me try to jump it again, but all I get is that "buzzing" sound, almost like a machine gun.
The engine light is not coming on.
I'm going to the local Oreilly's later today and will just buy a new battery and terminal connectors. The ones on my current battery do have rust/corrosion on them.
I have no idea what a starter solenoid is, but will look up some videos on that as well.
I'll update this later tonight or tomorrow and we'll see what happens.
I want to get this fixed because I really like this car.
Old 01 Aug 2018, 02:41 pm
I should add, I am worried it might be the timing belt, since the car would initially try to turn over, but wouldn't start.
After trying to start it a few times, and also after jumping, the "cranking" sound slowed down, then that's when the "buzzing, or machine gun" sound started.
Constant buzzing sound from engine. whiteclaw General PT Cruiser Discussions 19 08 Nov 2013 02:09 am
Turn Key No start No sound dlambunion Tech & Performance Forum 4 11 Sep 2013 10:44 am
car won't start, goofy sound jdmickies Tech & Performance Forum 6 21 Feb 2010 08:50 pm
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
Clank sound on Start up DaShado General PT Cruiser Discussions 2 01 Jul 2007 11:11 pm
