Any info on mixing E-85 with gas on GT turbo?
Like Tree2Likes
  • 1 Post By rob302
  • 1 Post By NitroPT
Old 03 Aug 2018, 05:56 am
Default Any info on mixing E-85 with gas on GT turbo?
I have a 2006 GT turbo, 3" exhaust from heard back with MF muffler and a cold air intake. I got a Diablo Sport 3. when I put a tune in it and it pinged. I tried 101 octane and I got 16 lbs of boost and no ping. ran great, can't afford $9.99 a gallon so a friend said to put about 4 to 5 gallons of E-85 to a 3/4 tank of 91 and it still ran great with 16 lbs of boost and no ping. Is it safe to do that or can I hurt the motor?
Old 03 Aug 2018, 07:18 am
Default Re: Any info on mixing E-85 with gas on GT turbo?
I'd ask that so-called friend to show me in his car first. The proof is in the pudding, so to speak. That's all I'm saying.
Old 03 Aug 2018, 08:56 am
Handy_Cruiser's Avatar
I'm running a custom tune with 15 psi and no ping on 93 octane. It's around $3.20 a gallon here.
Old 03 Aug 2018, 11:07 am
rob302's Avatar
E85 isn't a very consistent blend around here. Just adding 4-5 gallons would be a wildly inconsistent fuel tank to tank. plus since e85 requires 30% more fuel so your tune would be lean.
not sure where you are, but E85 is seasonal here. in winter it's actually E70 to help with cold starting.
i would correct the tune instead of dealing with the hassle of guessing with fuels. mixing it like that sounds like a lot of effort for a car that is not a race car.
chuzz likes this.
Old 03 Aug 2018, 01:35 pm
the diablo canned tune is just gonna be 93. i duno why you put 101 in it. This Euro?
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
Old 03 Aug 2018, 01:42 pm
Perhaps you meant to say min. 93 octane fuel recommended or required depending on the published date of the DS script. I have both instruction warning/cautions, one from a very old unit and the most updated version.
Old 03 Aug 2018, 01:45 pm
Yes, Minimun 93. Any higher octane isnt going to hurt, except for your wallet.
Old 03 Aug 2018, 01:49 pm
This mix type is not advised in the fashion being posted. If you run a specif gravity check you would understand why.
Most fuel injected engines and especially a super charged or turbo charged induction you could put small amounts of water in the furl tank(not saying anyone try it) and the fuel system would most likely push it through.
Just because you "THINK" the engine is running well on a chosen octane fuel and not pining only means you can't hear it! Unless you can watch your knock values you don't know what is going on in the real world. This goes without saying in any running condition of an engine. The human ear can not detect the low begin sounds of pre-ignition and when you do finally hear it you can bet your engines has been doing it for a while.
Old 03 Aug 2018, 01:57 pm
HAHAHA... maybe you meant to say that .... using higher octane fuels then recomend may not have any positive value (unless the engine is detonating) and would only hurt your wallet?
This is all subjective anyway. The first information, warnings, cautions or any other way you want to word it, is that the engine be in the good condition. This means that before adding anything that will increase the power output checking the engine is necessary and really logical. Most dont and simply assume it runs and may even run well so it must be in good mechanical condition?
chuzz likes this.
Mixing 1-shot with Rustoleum MikeGlosta The Detail Shop 12 03 Oct 2016 09:10 am
mixing manufacturers ok? 4SPEED The Detail Shop 2 23 May 2011 10:12 pm
Help Gen Turbo info turbomangt General Turbo Discussions 7 22 Dec 2005 03:02 am
Turbo Tech Info turbomangt General Turbo Discussions 1 13 Dec 2003 12:24 am
GT Turbo INFO V8BeatR Turbo Performance 9 01 May 2003 05:44 pm
