transmission fluid
Like Tree2Likes
  • 1 Post By Carl48
  • 1 Post By pt06
Old 15 Aug 2018, 04:56 pm
Default transmission fluid
Anyone running Amsoil synthetic ATF in their PT. The bottle says recommended for transmissions requiring ATF+4. Just looking for some actual experience.
Old 15 Aug 2018, 05:22 pm
Default Re: transmission fluid
The only real or best answers would be if anyone had the fluid analysis.
Just changing the the fluid and filter during a normal service is not likely to feel anything by using the better quality fluid then you would using standard ATK recomend fluid. .
https://www.blackstone-labs.com/
Transmission
Transmission and gear oils can be contaminated with metals, solids, and moisture, and those contaminants should be removed before they can damage the system.
Conversely, a test of your ATF, manual transmission fluid, or gear oil may reveal that it's still in great condition, and you don't need to change it as early or as often as you thought.
We can tell you what condition the oil is in, whether it needs to be changed , and whether the unit has any pressing mechanical issues that should be taken care of.
Transmission and gear oil samples can be sent in the same sampling container as engine oil samples, and you can use the same oil slip too. The cost is the same as for engine oil.
Old 16 Aug 2018, 05:40 pm
Nitro,
Good idea, have used them in the past for engine oil analysis.
NitroPT likes this.
Old 20 Aug 2018, 01:41 am
I'd stick with the Mopar ATF+4 type 9602. It was developed by Chrysler engineers with specific properties for their trannies. I believe it is a semi-synthetic.
chuzz likes this.
Where is the transmission fluid dipstick? siddharta1979 General PT Cruiser Discussions 8 06 May 2014 03:53 pm
transmission fluid deafy06 General PT Cruiser Discussions 7 06 Jul 2012 04:28 pm
transmission fluid partyd General PT Cruiser Discussions 7 09 Feb 2011 10:33 pm
Transmission Fluid scatgo Tech & Performance Forum 4 31 May 2009 09:04 pm
Transmission Fluid DaShado Tech & Performance Forum 1 02 Jul 2007 06:18 pm
