02 cruiser skipping bad after washing ngine
Like Tree2Likes
  • 2 Post By RickinPA
Old 26 Aug 2018, 07:56 pm
Default 02 cruiser skipping bad after washing ngine
Hi guys p, I need a little help,I pressure washed my engine on my 02 cruiser and when I went to start it,it almost didnít start up,engine would turn over but took a little while to start and when it started it acted like it was flooded, but it did crank up,I rev the engine a few times and it got better but still has a bad skip in it,I thought I might have knocked a wire or hose off so I checked everything out,but found nothing loose. I thought it might be a sensor, but it has not turned on the check engine light,. So anybody got any ideas. Thanks guys
Old 26 Aug 2018, 09:55 pm
Default Re: 02 cruiser skipping bad after washing ngine
There is a wire harness that comes down from the engine when the clamp breaks hitting the half shaft or frame. This happens on the 2001 and 2002 Pt Cruisers.
Old 27 Aug 2018, 10:17 am
Take your air filter out and make sure there's no water in the air box. Other than that, I'll ask if it was running okay before you douched it? If so, you've probably got water in a connector. I'd just start taking each connector loose and drying them out. Long, pain in the neck process, but maybe it'll work.
Old 27 Aug 2018, 07:06 pm
RickinPA's Avatar
I'd say check the spark plugs. They sit in tubes and the wires are more or less sealed to the valve cover, I think they're fairly well protected from incidental water exposure, but I doubt they are protected from the onslaught from a pressure washer.
pt06 and Handy_Cruiser like this.
Old 27 Aug 2018, 07:33 pm
LionPT's Avatar
Check your oil for water, if you find any..change it right away.
skipping gears ProDigit General PT Cruiser Discussions 12 29 Oct 2010 10:09 pm
Radio Constantly Skipping. Cathy06PT Sound and Security Forum 3 27 Mar 2009 10:59 pm
Check engine light, skipping ab1 Tech & Performance Forum 2 02 Aug 2008 11:13 pm
Washing the ragtops? Ric Easton PT Cruiser Convertible Forum 0 27 Jun 2004 06:20 pm
Car washing? amazingarthur The Detail Shop 10 21 Jan 2004 10:17 pm
