P0441 Evap System -- could be PCV valve
  • 1 Post By Lieuallen
Old 27 Aug 2018, 06:39 am
Default P0441 Evap System -- could be PCV valve
My check engine light came on, and I got a code P0441 (Evap Emissions). Took it to the shop, since I can't diagnose it, and didn't want to deal with lowering the fuel tank (if it needed that). After quite a bit of diagnostic work, it turned out to just be a bad PCV valve! Shoot -- I could have fixed that!
So, just a note for future PT Cruiser owners -- a code P0441 could simply mean you need to replace your PCV valve. Save yourself a lot of time and money -- check it before you take your Cruiser to the shop!
svtnos likes this.
Old 27 Aug 2018, 08:06 am
svtnos's Avatar
Default Re: P0441 Evap System -- could be PCV valve
shoot i wish mine was that simple.. i have codes for full evap system failure.. but eh who cares .. car still runs perfect..
2003 PT Cruiser limited edition
Old 27 Aug 2018, 01:00 pm
rsrocket1's Avatar
Good PSA!
While you're at it make sure the hose is still supple and flexible. Most will be hard and cracked which will lead to rough idling if it starts sucking air through the cracks.
Old 27 Aug 2018, 03:07 pm
My02RedRide's Avatar
Hose for my 02 got real soft and gooey and had cracks in it. Junk yard is your best friend..... I replace my valves every couple years when I do a "tune up".
2002 PT 4 door Inferno Red
2008 PT Convertible Bright Silver
Tags
p0441, pcv valve
evap system Carl48 General PT Cruiser Discussions 0 04 Jun 2018 05:57 pm
EVAP P0441 over tank parts list? Bleys Tech & Performance Forum 1 08 Nov 2015 11:51 am
evap code p0441 "03 Limited" peteycruise Tech & Performance Forum 4 19 May 2015 07:24 pm
Evap System - Not Gas Cap dveldt Tech & Performance Forum 5 20 Jul 2013 06:09 pm
Help Troubleshooting the EVAP system geronimo Tech & Performance Forum 6 09 Mar 2009 09:46 am
