To change or not to change... that is the question
Like Tree5Likes
  • 1 Post By Fk5
  • 2 Post By Sinbad
  • 1 Post By Sinbad
  • 1 Post By Fk5
Old 19 Sep 2018, 04:27 am
Sinbad's Avatar
Default To change or not to change... that is the question
Gearbox oil on a Getrag 5 speed... same box as all PT's but slightly different ratios for the diesel
260K Km (162K miles)
It has what I would call "a bit of a growl" - nothing loud or scary, but that kind of hollow low whine which sounds to me like final drive more than gears
It's in all the gears, so again, final drive rather than gears methinks unless anyone has any other ideas.
I know these are sposed to be "sealed for life" but that means diddly to me - oil should be changed, it wears out, and 160000 miles is a lot... BUT you hear horror stories about the boxes going tits after the oils changed
Whats the consensus? leave well alone or change the slippery stuff?
PS: it doesn't change that well - not bad, but not exactly like butter - but then at 160K what do you want..?
_________________________________________
'07 2.2 CRD
Old 19 Sep 2018, 07:33 am
Default Re: To change or not to change... that is the question
I'm not familiar with the Getrag, but every manual shift gear box I've ever owned had a drain plug and a fill plug. Sometimes a funnel with a long piece of hose attached and someone to pour the new gear oil in while I was under the car to put the plug in was needed, but I always changed mine after 100,000 miles. You should either change it yourself or take it to a REPUTABLE shop. I'm not sure what type of fluid the Getrag takes, either. You need to make sure the correct stuff goes in or it might go tits up.
Old 19 Sep 2018, 10:08 am
Fk5 Fk5 is offline
All PTs do not have a Getrag. Most have a New Venture 350. The GTs, like mine, have a Getrag 288, I believe. They all should have a drain plug and a fill plug. The fill plug doubles to check fluid level - you fill it until it runs out. Once it stops you're good. I think the NV350 has a rubber fill plug, but on the Getrag you should make sure the fill plug comes out before you drain, otherwise you might not be able to refill. most people use one of those little pumps you get at Harbor Freight, but I have heard of people using a funnel with a long hose. I think they call for ATF+4, but I am not sure what conventional wisdom is for what to use. I know you have a diesel, so YMMV. I should be doing this job shortly.
Sinbad likes this.
2003 GT 5 speed
162,000 miles
Old 19 Sep 2018, 04:34 pm
Sinbad's Avatar
Thats all as per the book FK - including the good advice on "Fill Plug First"
It is ATF4 - but the service manual doesn't give a change interval - they only show a drain as a prelude to working on the box.
I think I'll follow my instincts and change it.
What could possibly go wrong...
rckstein and Fk5 like this.
'07 2.2 CRD
Old 19 Sep 2018, 07:00 pm
rckstein's Avatar
Famous last words
Old 19 Sep 2018, 07:14 pm
rckstein's Avatar
Per the Owner's Manual, change the manual transaxle fluid every 48,000 miles:
I follow Maintenance Schedule "B" for my PT because it takes into consideration harsher driving conditions and environment.
Old 20 Sep 2018, 01:36 am
Sinbad's Avatar
I've never seen an owners manual
My gearbox has never seen new oil either
Well thats that then. Oil change it is...
rckstein likes this.
'07 2.2 CRD
Old 20 Sep 2018, 08:30 am
Fk5 Fk5 is offline
Cool. I have only missed 3.4 changes!
2003 GT 5 speed
162,000 miles
Fuel economy change with tire size change? Calab Tech & Performance Forum 7 11 Aug 2011 06:24 pm
QUESTION ABOUT TRANSMISSION OIL CHANGE ON A 06 PT CRUISER Cyclone35 General PT Cruiser Discussions 12 02 May 2011 11:53 pm
Plug change procedure question sawdust123 General Turbo Discussions 14 07 Dec 2007 04:04 pm
Oil change question. stirfry General PT Cruiser Discussions 8 21 Jun 2004 11:46 am
Your change to see the Presto Change-O in person! Got My PT Vendors & Buyers Forum 0 04 Oct 2002 07:45 pm
