Recurring problem with A/C or engine.
Like Tree14Likes
  #31 (permalink)
Old 09 Oct 2018, 06:28 pm
rckstein's Avatar
Default Re: Recurring problem with A/C or engine.
Doesn't the IAC add a few rpm's at idle when the A/C is turned on?
  #32 (permalink)
Old 09 Oct 2018, 09:15 pm
On my silver Pt Cruiser it maintains the same rpm's. If the IAC was not working you would see a drop in rpm's when you turn on the A/C.
  #33 (permalink)
Old 09 Oct 2018, 09:43 pm
rckstein's Avatar
That's what I mean, maybe the IAC on his PT isn't working correctly, and when he turns on the A/C, that's what causes the RPM's to dip so low?
Originally Posted by Rumble View Post
No, it doesn't seem to increase any when A/C is engaged. Maybe I need to disconnect the battery and see if that will reset things?
This is from the Service Manual:
sanatanadharma and pt06 like this.
  #34 (permalink)
Old 10 Oct 2018, 09:20 am
The A/C needs to be checked to make sure it is working properly before looking at the IAC. If you are low on freon, compressor is not working properly, etc. it might also effect the rpm.
  #35 (permalink)
Old 10 Oct 2018, 03:41 pm
Would a faulty IAC show a code? Oddly enough, I replaced an idle air module on my truck (92 Chev) a few months ago.
Tags
a/c problems, timing belt
Recurring radiator fan failures Gsnewsome General PT Cruiser Discussions 6 30 Jan 2017 12:11 am
2001 PT Auto Trans Problem and Engine Rev Problem johnwwjr Tech & Performance Forum 4 18 Apr 2015 10:00 am
Recurring dead battery SteamboatWillie General PT Cruiser Discussions 8 03 Jun 2014 09:25 am
Recurring P0344, Camshaft Position Sensor reading 04PTneedshelp Tech & Performance Forum 8 27 Feb 2014 11:51 pm
Engine problem??? CHROMEDCRUISER Tech & Performance Forum 12 07 May 2004 01:35 pm
