Depressurize Fuel System on 2006 PT Cruiser
Like Tree6Likes
Old 31 Oct 2018, 04:32 pm
Default Depressurize Fuel System on 2006 PT Cruiser
I need to replace the fuel line in the engine compartment of a 2006 PT Cruiser. The factory repair manual says to first disconnect the fuel pump relay and run the engine until it stops. This is done to depressurize the fuel system. However it appears that in 2006, the factory eliminated the relay that was dedicated to the fuel pump. Does anyone know how to best electrically disconnect the fuel pump so that the fuel line can be depressurized?
Old 31 Oct 2018, 06:20 pm
Handy_Cruiser's Avatar
Default Re: Depressurize Fuel System on 2006 PT Cruiser
If your fuel line is leaking, it should leak off the pressure within an our of the key being off.
Old 31 Oct 2018, 07:00 pm
Thanks for the response. Makes sense.
I'd still be interested know the answer to my original question about the best way electrically disconnect the fuel pump, so that the engine could be run and depressurize the fuel system. I think this would be useful if someone needed to replace the fuel pump and the fuel system was leak free.
Old 01 Nov 2018, 12:18 am
Should be a fuse in the box. Pull it
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 01 Nov 2018, 03:00 am
The factory manual is wrong. 2006 is the first year of the TIPM system on PT Cruisers. There is a six wire connector on the side of the fuel tank. The two larger wires [ 1 black --- 1 dark green/white ] supply the fuel pump motor. Unplugging the connector will stop the fuel pump from running. And should allow the motor to turn over. I've never tried it.
Handy_Cruiser and rob302 like this.
Old 01 Nov 2018, 07:26 am
Here's what a Chrysler tech posted about this on JustAnswers.com.
To be honest with you we just use a couple of shop towels and wrap them around the fitting then loosen it slowly and all the pressure drops real quick. Works real well because even if you get the pump to shut down and the engine stall, it still has pressure in the lines because the injectors shut it off when pressure drops but there is still a lot of pressure still in the lines.
https://www.justanswer.com/chrysler/...-pressure.html
I have personally done this on my 2007 PT and it's no big deal.
Handy's New Turbo Convertible PT Project!
Old 01 Nov 2018, 10:39 am
rob302's Avatar
handy i would bet that was a UTI graduate that wrote that.
unplug the one and only electrical connector on the fuel tank. it is on the side of the tank, the right/passenger side by all the evap crap.
once disconnected, crank the vehicle and the fuel injectors will purge the pressure.
or do it the arkansas way. i've had gas catch on fire 2x and it usually kills my buzz, so i try to avoid it
Last edited by rob302; 01 Nov 2018 at 11:16 am. Reason: just saw PT06 already wrote this. lol
Old 01 Nov 2018, 11:54 am
A UTI graduate? That would be amazing. My son has two buddies that do this for a living. Based on those knuckleheads, I assumed you only had to graduate from reform school to work in a dealership shop.
The amount of fuel loss from this particular pressurized and depressurize line is not that different. Pressurized, you just get a quick spray and with a rag around it, not so much. Depressurized you still get some fuel running out of the line. Overall, this risk should be pretty low without a buzz. I wouldn't recommend anything I wouldn't do myself and not feel safe about it.
Now as for the way I checked the injectors and found the crack in the rail, that's more for the "advanced hillbilly". So I won't go into that one.
rsrocket1 likes this.
Old 01 Nov 2018, 05:54 pm
rsrocket1's Avatar
Quite frankly, I did just that when taking off the injectors during my head gasket job. I don't think there was even 1 teaspoon of fuel that came out and a single shop rag caught all of it. There's a Schrader valve under the end cap on the driver's side of the fuel injector rail that you use to depressurize the fuel rail. The engine off pressure isn't that high and the fuel just dribbles out.
https://youtu.be/CLoL3D1rM2o?t=297
Handy_Cruiser likes this.
Old 02 Nov 2018, 10:30 am
rob302's Avatar
After 2005 or so, Chrysler removed the Schrader valve to save 2, so this is not an option for this guy
2006 PT Cruiser electrical problems Fuel guage, all lights right front JoeX Tech & Performance Forum 2 10 Oct 2016 09:24 am
2006 PT Cruiser Fuel Problem Walenore2014 Tech & Performance Forum 1 03 Aug 2016 09:31 pm
2006 PT Cruiser Fuel Pump Relay Sweaty_AZ Tech & Performance Forum 2 09 Jun 2014 08:11 pm
Q's: Fuel System, Cruise Control, and more... Kittera Tech & Performance Forum 0 31 Jan 2014 01:59 am
Fuel system cleaning Travis2k7 Tech & Performance Forum 4 01 Jun 2009 08:49 am
