2002 Rear Window defogger not working
  • 1 Post By wow77
Old 01 Nov 2018, 08:23 pm
Default 2002 Rear Window defogger not working
I tested all the fuses and the rear window defogger switch and everything is okay (according to the service manual)on my 2002. I find that I am getting current to the rear view mirrors (they are warm ) but current is not going back to the white / black wire to feed the rear window defogger grid. Where would I look next? is it a problem with the mirrors? the wiring schematic denotes a black and white feed to the rear view mirror however I can't find one when I open up the wiring feed at the door.
Old 03 Nov 2018, 07:29 pm
Macgyverman1123's Avatar
Default Re: 2002 Rear Window defogger not working
I would try to trace the wiring from the mirrors back. Does the rear glass heat up at all? Just a tiny bit? Very slowly? Nothing at all? Does the grid appear to be damaged at all? Sadly, fixing the wiring may involve tearing apart the trunk lid lining and or the headliner. Good luck!!
Old 08 Nov 2018, 02:10 am
Default Re: 2002 Rear Window defogger not working - UPDATE
Yes, had to test the wires to the rear grid for current. Not hard to pull panels off.
Result - the black ground wire as well as the black/white wire were broken. They were in the black boot that protects the wires when you open the rear hatch. Apparently afer many repeated open and closes they just broke.
Oh, it's a 2002 with 265,000 miles. And yes I do use that rear deck door a lot.
Pwr Windows/Blower Fan/Back-up lights/Rear Window Defogger/Air Bag Light elgeeps Tech & Performance Forum 12 20 Oct 2014 10:19 am
left electric window on 2002 ptc limited edition not working stanley General PT Cruiser Discussions 1 22 Jan 2013 07:45 am
Rear Window Defroster not working after head gasket repair - 2005 PT Cruiser easkey Tech & Performance Forum 4 26 Dec 2012 01:52 pm
Rear window defroster not working ukbeachbum General PT Cruiser Discussions 8 16 Nov 2011 09:56 am
Rear Screen Heater/Defogger Jassy General PT Cruiser Discussions 3 07 Nov 2011 10:43 am
