classic antifreeze harm anything?
Like Tree6Likes
  • 4 Post By NitroPT
  • 2 Post By Handy_Cruiser
Old 05 Nov 2018, 03:47 pm
Default classic antifreeze harm anything?
OK the sticky said don't mix antifreeze types. Well, just replaced the water pump inlet tube an hour ago. Only water was in the radiator etc. I put in classic green antifreeze. How urgent is the using of HOAT antifreeze? Will the green stuff harm anything other than needing replacement sooner?
Old 05 Nov 2018, 03:53 pm
Default Re: classic antifreeze harm anything?
If as you said there was only water you can use other antifreeze. The important thing is to read the labels for compatibility when adding to an already running cooling system with coolant in it.
Old 05 Nov 2018, 06:03 pm
LionPT's Avatar
I bought mine with Green already in it.
When I had the timing belt, water pump & head work done...they put Green back in.
Old 05 Nov 2018, 07:26 pm
Handy_Cruiser's Avatar
Most new name brand antifreeze is compatible with HOAT. Just read the label as already advised.
If you don't know the history of the car, I recommend flushing the cooling system and then refilling.
If left in too long, the older HOAT will sometimes cause a rust-colored sludge. And if HOAT got mixed with older "classic" antifreeze, it can create a black sludge. Both sludges can reduce the efficiency of the cooling system and clogged the radiator and/or the heater core. So by flushing the system, you may be able to remove some of any past "sins" done by adding the wrong antifreeze in years past. Plus, once the system is thoroughly flushed you can use whatever quality antifreeze you like without worry.
This is pretty well standard practice for me anytime I buy a used car.
Matt42 and myckee like this.
Which antifreeze? OneBadCruiser Tech & Performance Forum 16 02 Mar 2013 06:18 pm
antifreeze javolier Tech & Performance Forum 5 12 Sep 2011 02:49 pm
antifreeze? fattmann Tech & Performance Forum 3 04 Jul 2010 12:29 am
Antifreeze PTGT Redman General Turbo Discussions 3 27 Sep 2003 01:21 am
