screamed till it stopped
Like Tree4Likes
  • 2 Post By Sinbad
  • 2 Post By MJKnight
Old 28 Nov 2018, 06:46 pm
MJKnight's Avatar
Default screamed till it stopped
PT 3 has sat about six monthS, started it Tuesday
The power steering was noisy.. does that in 30 *
weather..just on start up though..
but was constant...well today it stopped ,(see pics)
but now it don't steer so very well..duh
I had some foaming and over flowing also..
but never seen a line break like this any ideas?
its broken where it goes into the pump.
Thanks Mike
Old 29 Nov 2018, 07:58 am
Default Re: screamed till it stopped
I've NEVER seen a line break like that. It looks like it's been cut. Seems that now is the time for a new line. And you may want to take the pump off and give it a good cleaning. If you don't want to take it off, at least clean the screen. Several members here have done that so you should be able to search it and find out exactly what they did.
Old 29 Nov 2018, 01:18 pm
Sinbad's Avatar
My air con pipe was snapped like that, directly where it met the compressor.
I'd be checking engine mounts before I fitted the new pipe, because I suspect that's what did for my air con. One of the engine mounts was almost new when I bought the car - it's odds on it was replaced because it was so shot, it broke the pipe...
I drove the 2.0L half way across Europe and back with no PS when a bit of crap jammed the pressure release on the pump open.
Wasn't too bad, so long as you kept it moving.
Fk5 and chuzz like this.
_________________________________________
'07 2.2 CRD
Old 13 Dec 2018, 09:34 pm
MJKnight's Avatar
Just finished up replacing the power steering hose
was not that bad..other it took 2
people to put the belt back on..
not sure what caused it to shear off,,other than
one of the hose brackets on trans,,was loose..
I used this link for the replacement instructions..power steering high pressure hose
Old 14 Jan 2019, 04:05 pm
MJKnight's Avatar
Well that didn't last long...
Started screaming again...
Then busted the line in the same place...
I googled it found same problem. ..
Was caused by a plugged canister...
Old 14 Jan 2019, 06:03 pm
RickinPA's Avatar
Here's how I cleaned the reservoir screen and flushed my power steering:
how many miles till gas light? rambojoe Tech & Performance Forum 18 14 Feb 2017 02:51 pm
Wait till you see this........ turbomangt General Turbo Discussions 12 01 Feb 2005 03:34 pm
i'm out of town till 2-3-05 tthrift Vendors & Buyers Forum 2 30 Jan 2005 04:51 am
Wait till U see this turbomangt General PT Cruiser Discussions 9 09 Aug 2003 08:59 pm
