Immobilizer
Like Tree11Likes
Old 08 Dec 2018, 05:30 pm
Chriscokid's Avatar
Default Immobilizer
My 05 gt cranked and went 10 seconds twice before it no longer turns over. Al lights work and fob works. The immobilizer light stays on when key is in on position. Also the check engine light never illuminates. Any advice is appropriated. I have removed battery cable for ample time to reset, no change
[SIGPIC][/SIGPIC]2005 PT GT Vert
2004 Honda Aquatrax turbo Jetski
2006 Honda Aquatrax
1998 Dolphin 36' motor home
1949 Piper Clipper taildragger
Old 08 Dec 2018, 06:07 pm
Default Re: Immobilizer
Do you have a second chipped key you can try? I have seen them stop recognizing a key that is always used for some reason. When a spare key is used suddenly the original works again.
If the spare doesn't work, or if you don't have one, then there are a few possibilities for your key not working:
Ether:
You are trying to start the car without a chipped key,
The chip in the key is defective,
The skim module which reads the key is defective,
The wiring is broken/chewed/poor,
The PCM is defective.
Old 08 Dec 2018, 08:21 pm
Chriscokid's Avatar
Thanks for suggestions, my mechanic friend says ecm since the ce light never appears in the cycle of turning key on and off. But not sure, if someone could confirm on theirs Id appreciate.
I only have one chipped key.
2006 Honda Aquatrax
Old 08 Dec 2018, 10:42 pm
Does the FOB lock and unlock the doors to confirm if the Skim module is still communicating with the computer.
Old 09 Dec 2018, 08:41 am
sanatanadharma's Avatar
Looking at my electrical schematics and IIRC, a bad fuse can cause your problem.
One or both of the following fuses may be bad.
A bad fuse #16 in the dash fuse-block can cause a no crank condition.
Fuse #1 in the under-hood PDC protects the circuit feeding fuse #16.
Check it, if #16 is ok.
Always check fuses. The PT has numerous power feed circuits and a system is not always obvious; as above where two fuses are inline on one power circuit.
Posting in stealth is not friendly to this forum.
Old 09 Dec 2018, 09:52 pm
The RKE and SKIM systems are different.
Busted_PT likes this.
Old 09 Dec 2018, 09:54 pm
Very good. I always forget to include that one! Yes check your fuses!
Handy_Cruiser likes this.
Old 10 Dec 2018, 03:23 pm
They might be different but have voltage going to both.
Inside fuse panel position fuse #10 under the dash has a 10A fuse labeled "cluster - RKE SKIM. Fuse #10 provides power to both.
Check fuse #10 if the remote locks are not workng.
Old 10 Dec 2018, 08:00 pm
But that is not what you said. You said if fobs work, then SKIM is still communicating with the computer.
That's not the case as you now have learned for the first gens. The second gens combined SKIM and RKE into one module called SKREEM.
Old 10 Dec 2018, 09:08 pm
Myckee, as you posted I was not looking at the problem in the same view as you did. I was looking at it from the power feed point of view. Thanks for posting your view.
Anti Theft, Security and Immobilizer PTMD General PT Cruiser Discussions 7 25 Sep 2017 11:23 am
Need help! Accidentally triggered SKIM immobilizer now car wont start! nadier Tech & Performance Forum 16 24 Aug 2016 12:26 am
Immobilizer commosutra Tech & Performance Forum 24 14 Jan 2015 03:10 am
02 pt cruiser immobilizer vanhalen7174 Tech & Performance Forum 4 07 Apr 2010 12:47 am
