Power Steering Fluid Flush Method?
Like Tree2Likes
  • 1 Post By _PTGT03
  • 1 Post By MJKnight
Old 17 Jan 2019, 11:06 pm
Send a message via AIM to rcalzadilla Send a message via MSN to rcalzadilla Send a message via Yahoo to rcalzadilla
Default Power Steering Fluid Flush Method?
Need to flush old power steering fluid with fresh. Any suggestions on how to do this? thanks
2001 PT 107,000 Miles Ltd Edition
Old 18 Jan 2019, 01:03 am
_PTGT03's Avatar
Default Re: Power Steering Fluid Flush Method?
what you do is open the low pressure return line and direct the tube into a 5 gallon pail. if you need to get a male-to-male nipple and the identical inner diameter hose to extend the return line then plan to do it to keep your work area clean. and then you pour through about 3 times the system's capacity in fresh fluid ATF+4 from the opening while idling the engine. i even suggest adding a 1/8 can of seafoam trans-tune into the resorvoir, you can leave it in. that will clean up the varnish inside the lines and steering rack or your steering pump if it's old. never let the reservoir go empty, and in-between emptying the bottles shut off the engine.
podo2000 likes this.
Old 18 Jan 2019, 11:49 am
Thank you, I'll being doing that next. It sounds like I'm going to need some old towels to absorb the fluid when connecting and disconnecting. Is this correct?
Old 18 Jan 2019, 02:35 pm
MJKnight's Avatar
https://youtu.be/w6wWM4XIWhI
Good video from a member
Alfie1 likes this.
Old 18 Jan 2019, 04:01 pm
Thank you!
Power steering fluid Geno1 Tech & Performance Forum 3 22 Apr 2017 09:41 pm
Power Steering Flush and Screen Cleaning RickinPA PT Cruiser Videos 2 30 Mar 2015 04:21 pm
Power Steering Fluid Aquamarine General PT Cruiser Discussions 1 01 May 2013 04:21 pm
Power Steering Fluid jmack General PT Cruiser Discussions 12 25 Dec 2008 11:55 am
TSB on Power Steering fluid? PTGT Redman Tech & Performance Forum 10 31 Mar 2004 06:42 pm
