Help. Cv axle
Like Tree2Likes
  • 2 Post By PTloser32805
Old 26 Jan 2019, 06:32 pm
Default Help. Cv axle
At auto store now. 2001 pt. Non turbo auto.
I got the wrong axles. One is longer than the other and has rubber damper
Can’t find the right one
Can anyone help?
2001 non turbo. Auto
Old 26 Jan 2019, 07:13 pm
podo2000's Avatar
Default Re: Help. Cv axle
2004 PTGT 135Kmiles
Old 26 Jan 2019, 07:26 pm
Mine is different. Mine is longer. Has a rubber donut in the middle
Old 26 Jan 2019, 08:26 pm
Nitropt. Help me know I you know the answer
Old 27 Jan 2019, 09:52 am
My02RedRide's Avatar
Canít find the right one
Can anyone help?
Non turbo have unequal length half shafts. The passenger side or right side will be the longer shaft and usually have a rubber damper about midway.
2002 PT 4 door Inferno Red
2008 PT Convertible Bright Silver
Old 27 Jan 2019, 07:08 pm
I was wrong. The first one I got was correct.
Mine just looked longer because the joint separated and the rubber boot slipped making the metal shaft seem longer.
Just finished. New cv axles, ball joints. Tie rod ends.
Going for 4 wheel alignment soon.
rckstein and podo2000 like this.
Old 28 Jan 2019, 08:59 am
You're gonna do all that, you probably should have just replaced the lower control arms too. Just my 2 cents worth.
Old 28 Jan 2019, 09:30 am
I took it all apart 80,000??? Ago and I installed energy suspension bushings all around. I had no issues or noise, so I just left it.
The ball joints and tie rod ends are autozone lifetime replacement. So there free
Axle Ratio thecabinguy General PT Cruiser Discussions 3 15 Apr 2014 01:13 pm
How do I remove the CV Axle? SkeeJr Wheels, Tires, Suspension 8 15 May 2012 07:55 am
Axle Bolt janjentay10 Tech & Performance Forum 2 19 Apr 2012 11:41 pm
CV Axle GoosedF350 Wheels, Tires, Suspension 1 13 Dec 2011 09:59 pm
10K, 1 Year, & Needs New Axle??!! jlwn111 General PT Cruiser Discussions 28 27 Jun 2010 07:26 pm
