Speaking of CV joints...
  • 1 Post By chuzz
Old 29 Jan 2019, 05:41 pm
RVC RVC is offline
Default Speaking of CV joints...
I've got a decided clunking coming from what I figure is where the passenger side CV joint is. Clunking started a few days ago, was hardly noticeable and occurred only when I turned left. Now it happens pretty much all the time and is getting pretty obvious. Am I correct in assuming the CV joint is the problem and needs replacing?
Thanks.
RVC
2002 2.4L Woody Normally aspirated
Purchased 2/29/16 w/ 104,048 miles
Old 30 Jan 2019, 09:00 am
Default Re: Speaking of CV joints...
Generally, a defective cv joint or axle will provided more of a "clicking" sound than a clunk. Clunking could be a tie rod end link, sway bar bushing, lower control arm bushing or even a ball joint or strut bearing. A local tire shop SHOULD be able to check it for you free of charge. I know that TIRE BARN here in Lake Wales does it for free.
Slowrider likes this.
Old 02 Feb 2019, 01:11 pm
RVC RVC is offline
Thanks for your input, there Chuzz. As it turned out it was neither the CV or the other suspension parts you mentioned. I hate to admit this but as it turned out, when I replaced the front brake padsearlier I didn't tighten the lug nuts as tightly as I should have. They loosened further and resulted in the pretty sever clunking I ended up hearing. Pretty embarrassing to admit that but that's they way it was. Thanks again for your help.
RVC
Old 03 Feb 2019, 08:04 am
No problem, man. I hope you torqued them to 100 ft.lb.
CV joints/Axel Assembly Rekoj Tech & Performance Forum 1 17 Oct 2011 12:18 pm
ball joints with LCA installed? bobdole369 Wheels, Tires, Suspension 7 08 Oct 2011 09:02 am
NIB, ball joints f/s OurPTGT Classifieds: For Sale/Trade 0 30 Sep 2011 06:52 am
wich cv joints should i order ipath1 Tech & Performance Forum 5 17 Aug 2011 03:53 pm
Ball Joints android Wheels, Tires, Suspension 1 12 Nov 2004 01:48 am
