upper manifold removal
  • 1 Post By rob302
Old 06 Feb 2019, 04:55 pm
Default upper manifold removal
Attempting to change spark plugs and wires on a 2001 Limited.
Once un-bolted and disconnected from EGR tube, is it possible to rotate the upper manifold out of the way without removing all of the sensor connections? Some of them are refusing to come off and I don't want to break them.
Thanks!
Old 06 Feb 2019, 08:00 pm
rob302's Avatar
Default Re: upper manifold removal
yes. the family friend owned shop which i changed my plugs/wires/coil at handed me a bungee cord. after disconnecting the EGR, the bolt for the TB support bracket, and the upper to lower intake bolts, i bungee'd the upper intake to the hood with all the other crap still attached
LionPT likes this.
Old 06 Feb 2019, 09:54 pm
Macgyverman1123's Avatar
Yes! I've had to pivot the upper manifold out of the way (Not for plugs, though I do need them) and I was able to get enough room to completely remove the valve cover, so it'll be more than enough room for you to do plugs and wires! Don't forget to mark which points on the ignition coil go to which cylinder, and never, never never change plugs on a hot or even warm engine! Good luck!
Metal Upper and lower intake manifold for GT Pippov Classifieds: Want To Buy 7 30 Nov 2017 03:26 pm
looking for composite upper and lower intake manifold Ptworm Classifieds: Want To Buy 7 15 Aug 2016 06:12 pm
Upper manifold gaskets discovering06 Tech & Performance Forum 2 21 Jul 2016 12:20 am
Turbo PT Cruiser Upper Plastic Intake Manifold madscientistdohc Classifieds: Want To Buy 1 27 Jul 2015 08:40 am
WTB: UPPER INTAKE MANIFOLD Cokebear1 Classifieds: Want To Buy 0 03 May 2004 02:29 pm
