Changed motors now it won't start
Like Tree5Likes
  • 3 Post By _PTGT03
  • 1 Post By ptcruisersteve
  • 1 Post By rob302
Old 19 Feb 2019, 11:46 pm
Default Changed motors now it won't start
I have a 2002 Pt Cruiser Touring 2.4 automatic. It had a blown head gasket so i had another motor put in it , it came from a 2001 PT cruiser . Now that it's been installed it will not start ...doesn't crank . I told the guy that put the motor in that i read somewhere online that when you switch motors that you need the PCM that was with that motor but all he had was the motor . i can order a PCM from EBay but how would i get the correct ID number for it ? and would i need a different key , one that's programed for the 2001 ? If anyone can answer my questions and has any idea what I should do PLEASE help me . I love my PT Cruiser and it's my only means of transportation .
Old 20 Feb 2019, 12:20 am
Default Re: Changed motors now it won't start
If it was running before you switched motors and you installed another NA (Naturally Aspirated) motor
If it was a Turbo motor you would have had to install an other turbo motor.
The computer should be no problem unless I forgot something, I would first check the wiring going to the starter as
it is easy to install the green wire (I think its the color) on the wrong terminal causing a no crank/start.
When you get it to crank and it will not start - check the connector going to the cam-sensor and the ??? as the two connectors are the same configuration
and easily connected to the wrong sensor because of the close proximity to each other
PCM changes with Turbo. Will not work with NA
PCM are CANBUS starting 2006- will not work in earlier Cruisers
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 20 Feb 2019, 01:21 am
_PTGT03's Avatar
im just wondering what kind of mechanic you used when they made an engine swap for you but couldn't get it working as part of the job ?
It's largely impossible to be trying to diagnose this over an internet forum. your mechanic should be troubleshooting with the electrical diagrams to determine why there's no engine cranking before anything else is done.
rckstein, rob302 and the3dgm like this.
Old 20 Feb 2019, 01:56 am
As Joe posted, check and see if the camshaft sensor connector and the ignition coil connector got swapped. It happened to some other members.
pt06 likes this.
Old 20 Feb 2019, 06:16 am
There is a difference between 'doesn't crank' and 'cranks but doesn't start'. Assuming the 'doesn't crank' ---- when you try to start the car, turn the key to the run position. The fuel pump should hum for a few seconds, then go quiet. If no hum, check the ASD relay and wiring.
The PCM doesn't know or care about the engine. It only cares about the engine sensor values.
Old 20 Feb 2019, 08:50 pm
Does the lights dim when you try to crank? If so you might want to see if you have 12 volts going to the starter. If you have 12 volts going to the starter your engine might be frozen.
If not first check all your fuses.
Old 21 Feb 2019, 02:04 pm
Only possible compatibility problem I could find is if engine has a EGR or non EGR.
Look it up your self.Car-Part.com--Used Auto Parts Market
You would think swapping parts off the blocks would be less confusing than swapping ECUs. Considering all the other things the ECU controls.
Old 21 Feb 2019, 04:09 pm
rob302's Avatar
Probably left the green wire off the starter.
she never said she used a mechanic
Changed the fuel pump, it won't start UncleJerry General PT Cruiser Discussions 23 23 Oct 2017 03:34 pm
Changed timing belt/water pump and pulleys. Now it wont start 1337DirtAlliance Tech & Performance Forum 21 11 May 2017 12:20 pm
Error Code 0340, changed Cam Sensor, still won't start dave44602 Tech & Performance Forum 19 28 Nov 2014 02:53 pm
Timing Belt Changed and now will not start - HELP rhowle Tech & Performance Forum 3 18 Mar 2012 08:59 pm
Neon SRT Motors/GTPT Motors Only1Balto General Turbo Discussions 5 01 Jan 2011 07:04 pm
