Spurious oil light... how hard is it to change the sensor??
Like Tree15Likes
Old 27 Feb 2019, 12:03 pm
rockandroller's Avatar
Question Spurious oil light... how hard is it to change the sensor??
OK, I've been getting the spurious oil lamp warnings now and then the last year or two. But they are more frequent now! Oil level is fine, and it's being changed regularly...
Anyway I was wondering how hard it is to reach the sensor to change it out. I was able to change my cam position sensor quite easily from the top... but the oil sensor is in the back somewhere? Reachable from top, or is it an 'under-the-car' job?
2004 'Turbo Lite'
Old 27 Feb 2019, 12:36 pm
Handy_Cruiser's Avatar
Default Re: Spurious oil light... how hard is it to change the sensor??
It's located on the back of the engine block on the driver's side. You may be able to reach it from the top, but you will be working blind. It's a little easier from beneath the car.
This was one of the first things I did when fixing up the my PT Vert. Here's a link with some photos.
Handy's New Turbo Convertible PT Project!
Old 27 Feb 2019, 02:53 pm
Fk5 Fk5 is offline
As Handy said, not bad from under. I did mine is about 10 minutes and I am super slow. Did it on ramps in my friend's driveway. Hardest part is not breaking the clip on the connector.
Handy_Cruiser likes this.
2003 GT 5 speed
162,000 miles
Old 27 Feb 2019, 03:49 pm
rob302's Avatar
HOW TO: oil pressure sensor replacement
more or less posting this for the picture it contains
Old 27 Feb 2019, 04:00 pm
RickinPA's Avatar
Yeah, they're not to bad to replace, I've replace the oil pressure switch on my daughter's Neon, similar set-up.
There's a red clip on the connector you may, or may not, be able to see. The clip probably need to be slid to the side to release the connector (picture from Rock Auto):
It looks like a 27mm (1-1/16"?) 6-point socket will fit the connectors, but there's also a special socket for these connectors. They use a kind of funky 12-sided drive. Here's the socket I got for the Neon:
Go for it.
Old 27 Feb 2019, 04:35 pm
LionPT's Avatar
I've done it twice, once in Jan & again in Feb.
I did it from the bottom the 1st time & from the top the 2nd.
It's much, much easier to do it from the top...JMO.
I didn't drain the oil the 1st time, small mistake...drained it the 2nd.
rockandroller likes this.
Old 01 Mar 2019, 05:07 pm
Goonior's Avatar
I replaced mine last summer. I removed the battery, tray and the bolts holding the fuse box bracket. IIRC it took about 30 minutes to change it. I did buy the special socket from Advance Auto for about $12..
2004 N/A auto. Touring Edition (Died 2016 resurrected Nov 2017) bought for $100 Oct 2017 w/122k mi, died March 2019 143K mi, engine replaced with 2004 w/ 71K in October 2019. Added RBQ 6-disc changer w/Sirius. Replaced TB,WP, thermostat and gasket, front bearings w/one hub, ceramic pads w/new rotors, one brake caliper w/bracket, and lower control arm. More changes/repairs as the weather allows .
1999 300M 196k mi (now her daily driver)
"The most terrifying words in the English language are: I'm from the government and I'm here to help." Ronald Reagan
Old 01 Mar 2019, 09:10 pm
LionPT's Avatar
I just removed the air box & hose.
Old 08 Mar 2019, 07:40 pm
Thumbs up Re: Spurious oil light... how hard is it to change the sensor??
aaaaaaaaaaahhhhhhhhhhhhhhhhhhhhh…. that is VERY GOOD TO KNOW.
IN THAT CASE, I'll get the mechanic to do it when I take it in for oil change next month!
LionPT likes this.
2004 'Turbo Lite'
Old 10 Mar 2019, 05:12 pm
Macgyverman1123's Avatar
Way back in the day, I had to change mine. It still worked, but it was spraying oil all over the exhaust and smoking. If yours is greasy, spray it down with some brake cleaner to remove the oil so you can get a grip and remove the connector. I did mine from the top, but I've got very long arms. Good luck!
The Handy Camshaft Sensor Change Out Handy_Cruiser Tech & Performance Forum 20 05 Oct 2017 08:46 pm
Do I need to change sensor/s on my 5-speed..got auto throttle body shelbyzman Tech & Performance Forum 3 26 Jun 2013 04:52 pm
How to change the right front impact sensor? wvladimire General PT Cruiser Discussions 5 19 Jul 2012 11:09 pm
hard sto start after tb change. ironhands Tech & Performance Forum 3 20 Oct 2011 07:42 pm
cd player light burnt out-easy or hard to fix? melluna General PT Cruiser Discussions 0 19 Oct 2010 03:02 pm
