41TE issues
Old 28 Feb 2019, 10:20 pm
Macgyverman1123's Avatar
Default 41TE issues
Evening!
Fortunately, not on my car. But my parents have an '05 Grand Caravan that has a 41TE, like my car. Lately, it slips when going into reverse and first. All other gears work fine, shifting up and down. It's got a 700 and 740 code, last time I checked. Fluid is clean and full. I suspect the shift solenoid. Any ideas? I'm thinking of trying a junkyard part.
Old 01 Mar 2019, 04:57 pm
My02RedRide's Avatar
Default Re: 41TE issues
Try the solenoid pack. Just make sure the area on your folks trans is real clean... no dirt falling down in the ports.. Blow it out real good before your pull the solenoid pack. U-Pull will be the cheapest place...
2002 PT 4 door Inferno Red
2008 PT Convertible Bright Silver
Old 01 Mar 2019, 05:00 pm
Goonior's Avatar
P0740 code is torque convertor clutch malfunction.
P0700 is a generic transmission trouble code.
How many miles on it?
2004 N/A auto. Touring Edition (Died 2016 resurrected Nov 2017) bought for $100 Oct 2017 w/122k mi, died March 2019 143K mi, engine replaced with 2004 w/ 71K in October 2019. Added RBQ 6-disc changer w/Sirius. Replaced TB,WP, thermostat and gasket, front bearings w/one hub, ceramic pads w/new rotors, one brake caliper w/bracket, and lower control arm. More changes/repairs as the weather allows .
1999 300M 196k mi (now her daily driver)
"The most terrifying words in the English language are: I'm from the government and I'm here to help." Ronald Reagan
Old 01 Mar 2019, 06:21 pm
Has anyone ever changed or added fluid to it? The 41TE takes Mopar ATF+4 fluid only. Any other type of fluid will eff it up.
Old 01 Mar 2019, 06:33 pm
They've had it since new. It has 204,000 on it, it was rebuilt once at 80,000. It's got full, clean fluid. Various brands, but only ever certified ATF+4.
Old 02 Mar 2019, 10:04 pm
When I first looked this up only certain brands were acceptable for the Pt Cruisers by the manufacture.
Old 03 Mar 2019, 02:36 am
I'd start by dropping the trans pan and seeing how much grunge is there. Also check the filter for grunge and replace it. Clean the pan. About 5 quarts of ATF is required. Start with 3 qts. and stick it.
Changing the solenoid pack with a used [unknown functioning] pack is a gamble. A new aftermarket one is about $60 [?]. There are little round screens in the solenoid pack passages. Look to see if they are plugged.They can be cleaned. Check wire connector carefully for corrosion.
Old 03 Mar 2019, 07:16 am
It's not his PT, Steve, he's referring to his parents 2005 Grand Caravan.
Old 08 Mar 2019, 02:05 pm
Thanks Chuzz
I met to say that a specific vehicle manufacture might only recommend certain brand transmission oil like the Pt Cruisers.
41TE Upgrade SilverSleeper Turbo Performance 10 29 Aug 2013 05:21 pm
41te with a TD06 SilverSleeper Turbo Performance 3 23 Feb 2011 09:32 pm
41te question b1gW00d Tech & Performance Forum 3 28 Jan 2010 07:09 pm
41TE Upgrade Kit SilverSleeper General Turbo Discussions 6 17 Dec 2009 10:27 pm
41TE torque rating twallyf Tech & Performance Forum 5 28 Jul 2004 10:13 am
