5 speed hard to shift sometimes
Like Tree6Likes
  #21 (permalink)
Old 13 Mar 2019, 05:34 pm
shelbyzman's Avatar
Default Re: 5 speed hard to shift sometimes
Got the 8mm socket but can't get it to budge. Not the greatest room to work with under there . I'm a little under the weather and that isn't helping any. I did spray it wilth wd 40 but didn't seem to help
2007 PT Cruiser GT 5-speed 17x8 Konig Inception wheels Drop-in K&N & airbox mod Spec D tail lights Blow off plate 10.2mm plug wires
  #22 (permalink)
Old 13 Mar 2019, 08:42 pm
They tend to seize in there since it's a steel plug in an aluminum case. I was putting quite a bit of force into mine to the point I thought I was either going to break the socket bit or strip the hole. I got a propane torch and heated up the plug a bit. The heat helps expand it slightly to break it free from the case. After the heat it came out fairly easily.
  #23 (permalink)
Old 13 Mar 2019, 08:59 pm
shelbyzman's Avatar
Thanks for the idea. I have a heat gun...you think that would work the same way?
  #24 (permalink)
Old 13 Mar 2019, 09:38 pm
_PTGT03's Avatar
Thanks for the info! Any idea where I would get that rubber plug? I don't know what it's called or a part number I would hate something to bounce up in there...probably could do some damage I assume. Guess I just need to get the diameter of the whole and get a plug that size.
there's no need to get a plug there. nothing will go in there except maybe some dust but that wont do anything. its going to be full of clutch dust in there.
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings 3" exhaust elbow, Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
  #25 (permalink)
Old 13 Mar 2019, 09:40 pm
_PTGT03's Avatar
No. That does NOT get hot enough. But, try it/
One time I had to remove a 1/2 NPT plug in a front axle for a medium sized forklift. It had seized so much that I had to heat it up to a glowing red colour with an oxy-acetylene torch. And then remove it with an impact gun. So a lot of concentrated heat is required. I actually broke off my ratchet square drive trying to remove it. Reinstall the plug and use anti-seize.
  #26 (permalink)
Old 14 Mar 2019, 10:03 am
shelbyzman's Avatar
Got the boot to break loose finally. Added a little fluid but it didn't need much. Car is still very hard to get into gear....probably going to have to have it looked at.
  #27 (permalink)
Old 14 Mar 2019, 10:25 am
shelbyzman's Avatar
Where is the clutch revervior on an 07 pt cruiser? Pics online show it being right by the brake fluid revervior but it isn't there on my car
  #28 (permalink)
Old 14 Mar 2019, 01:13 pm
Fk5 Fk5 is offline
I don't know about the 2007. That is where it is on my 2003 GT. Do you have the correct manual? Handy has some up on google docs. He has both a Gen1 and a Gen2. I suggest you take a look at the Gen2. There are a lot of significant differences, as a bunch of running changes. Here is a "link to the link":
Free 01-04 PT cruiser shop manual
Don't mind the title, that is the title of the thread, but the post is for Gen2
2003 GT 5 speed
162,000 miles
  #29 (permalink)
Old 15 Mar 2019, 08:51 am
shelbyzman's Avatar
Thanks for the link! I'm having my cousin work on the trans as well as changing out the timing belt....not looking forward to the bill
shift lever hard to move Carl48 Tech & Performance Forum 11 15 Jan 2017 03:19 am
Hard Down shift? red98gt Tech & Performance Forum 0 07 Aug 2014 03:57 pm
Manual trans hard 1-2-1 shift elcam84 Tech & Performance Forum 12 05 Jul 2012 08:05 am
Very hard to shift into first and second gear Sloanr333 General PT Cruiser Discussions 6 30 Apr 2012 11:18 pm
Hard to shift into reverse opelenvy Tech & Performance Forum 5 28 Jun 2007 09:55 pm
