PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/)
-   Tech & Performance Forum (http://www.ptcruiserlinks.com/forum/tech-performance-forum/)
-   -   Timing Belt Sprocket (http://www.ptcruiserlinks.com/forum/tech-performance-forum/66666-timing-belt-sprocket.html)
PTJoey 12 Mar 2019 04:23 pm
2003 Limited Edition, 43.3K miles
Prompted by a leaking water pump, my car is at the local dealership for a water pump and timing belt replacement (both original). The dealer called me to say that one of the timing belt sprockets had a few bad teeth and also needed to be replaced. Is this something to be expected for a 16-year old (but low mileage) vehicle that has never been driven roughly? I can't say that I noticed any clues. Thanks.
rcktpwrd 12 Mar 2019 04:31 pm
Re: Timing Belt Sprocket
can't say I have heard of any of the sprockets breaking or loosing teeth before... If that happened i would think the car wouldn't run correctly as the timing of the cam(s) would be thrown off.
Handy_Cruiser 12 Mar 2019 05:30 pm
I've never heard of this on a PT Cruiser. But there's always a first time. Go to the shop and ask to see the sprocket. Snap a photo with your phone and post it here.
Also, these sprocket are around $5 each at many salvage yards where you pull your own parts. And almost all the ones I've ever seen are pristine. ;)
rsrocket1 12 Mar 2019 05:37 pm
or $30 through a mail order Mopar dealer:
https://www.factorychryslerparts.com.../04667609.html
or $40 MSRP. I'm sure the local Chrysler dealerships around here would charge about $50-$60 though.
Having taken these things off several times, they are really strong. I'm also surprised that teeth broke off from yours.
Grasshopper77 12 Mar 2019 07:46 pm
Wouldn't be surprised if the dealer damaged the part and they try to get you to pony up for their mistake.
nj318 13 Mar 2019 03:25 am
It is definitely not a common issue. Maybe the sprocket was damaged during production or when the shop worked on it (using pliers to hold them for remove the fastening bolt).
Since it is made of metal and the belt obviously not, it's highly unlikely to lose any theeth during normal operation. :eek:
If it lost more than one or two, that would be the result. Most likely the belt would have been damaged, too, or at least show some unusual wear. So it might be a good idea to get a look at the belt, too.
But, on the bright side: they have to come off anyways to do the water pump, so its "just" a couple of bucks for some new sprockets. Work is the same. :dance2:
PTJoey 13 Mar 2019 07:33 am
Thanks for your comments. Dealer is charging me about $60. for the part which he is getting from another local dealer. You have confirmed my suspicions that mechanic may have damaged it. I'll investigate further.
PTJoey 15 Mar 2019 01:25 pm
Turned out that the damaged part was actually the crankshaft sprocket. The teeth were Ok; it was the back surface of the sprocket that had a chip. My guess is that the mechanic damaged it, but who knows for sure? Otherwise the car is running fine.
rckstein 15 Mar 2019 02:34 pm
Your PT averages about 7 miles per day.
Getting 16 years of use before the first timing belt change, you did real good :cool:
PTJoey 15 Mar 2019 05:31 pm
Thank you. I was clearly on borrowed time, but probably would have continued further were it not for the leaking water pump.
Appreciate the valued advice and knowledge received on this forum.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240
