Throttle Body Auto vs Manual (with turbo)
Like Tree8Likes
Old 15 Mar 2019, 08:57 am
shelbyzman's Avatar
Default Throttle Body Auto vs Manual (with turbo)
I have seen some posts about this but really still don't know for sure what the true answer is. Years ago I had a manual (non turbo) pt and changed out the throttle body with an auto one and noticed a big difference in throttle response. I am wanting to do the same with my 07 GT manual, but want to know if my throttle body is bottle-necked or not since it is a turbo. If it is, I want to change it out..just don't want to mess with it if they are the same size.
2007 PT Cruiser GT 5-speed 17x8 Konig Inception wheels K&N style intake auto throttle body Spec D tail lights Blow off plate 10.2mm plug wires Cat-Back "DNA Motoring" exhaust w/ Thrush glasspack "blacked out" DIY ground effects added boost gauge (in place of analog clock)
Old 17 Mar 2019, 03:02 pm
_PTGT03's Avatar
Default Re: Throttle Body Auto vs Manual (with turbo)
Never heard of that before. The bottle neck of your engine will be your PCM. Having a modified tune is the most cost effective and realistic performance modification. Keep everything else stock and in good running order.
Old 17 Mar 2019, 07:11 pm
shelbyzman's Avatar
From what I have read, the throttle bodies on the manuals were tapered so it would be easier (smoother) for poeple taking off with the stick shift.
Old 17 Mar 2019, 11:08 pm
Fk5 Fk5 is offline
I read that too. As far as I can tell, it is either BS or NA only. When I pulled an extra intake for my '03 GT, I took the throttle body too since it was basically a throw in. It was from an automatic and identical to the one on my manual trans car, they both had the same size stamped on them. 57 IIRC. I think I read there was some kind of plastic piece which could easily be removed.
2003 GT 5 speed
162,000 miles
Old 18 Mar 2019, 03:14 pm
shelbyzman's Avatar
I know that the non turbo 5 speed I had did have the throttle body that was tapered on one side. I may take mine off my 07 GT and measure to see if they put one on it like that as well. Doesn't cost me anything to check
Old 18 Mar 2019, 03:39 pm
My02RedRide's Avatar
The cam on the throttle arm where the cable rides on is different manual vs automatic. Did the swap on my 98 NEON R?T 2.0 DOCH from manual to auto TB and what a difference. Was larger diameter also… no neck down in size.
2002 PT 4 door Inferno Red
2008 PT Convertible Bright Silver
Old 18 Mar 2019, 03:43 pm
Fk5 Fk5 is offline
Are you sure this is true of the turbo PT? I have noticed no difference in my driving experience in the two years since I changed mine. I know the diameter is the same. I have no idea about the cam, but it all looks the same to me.
2003 GT 5 speed
162,000 miles
Old 18 Mar 2019, 04:18 pm
The throttle plate without the tip/in flow wedge will improve the top end performance. I doubt to much else would change at lower engines speeds.
The tip/in flow wedge reduces the total air flow rate at the starting of the intake system during manual shifting.
myckee likes this.
Old 19 Mar 2019, 09:48 am
They all, manual and automatic seem to have the same size throttle flap at 52mm. However, there are other differences. As well as the plastic "tip in wedge" most manual cars came with, they also had a reduced diameter inlet. The manual inlet is reduced to about 46mm, whereas the automatic does not have a reduced inlet at all and is ~52mm in and out.
I posted a picture a couple of years ago here of the reduced, 46mm inlet from my 03 manual GT. I am sure it is still visible if you search for it.
Fk5 likes this.
Old 19 Mar 2019, 11:52 am
Fk5 Fk5 is offline
I will have to look for that picture. I guess they were both stamped 52, but I held them up to each other and they sure seemed identical. I didn't use calipers, but it wasn't anything noticeable. I am sure that my manual trans throttle body was from a 2003 GT, but I don't know where the auto one came from other than that it was an auto trans car in the yard with an aluminum turbo manifold.
2003 GT 5 speed
162,000 miles
2.4 N/A auto Throttle body on 2.0 manual..? Sinbad Tech & Performance Forum 3 30 Nov 2016 03:26 pm
auto throttle body on my manual really help performance? shelbyzman Tech & Performance Forum 10 23 Jun 2013 08:40 pm
Automatic/Manual throttle body.the same?? 6banger Tech & Performance Forum 3 05 Dec 2009 10:06 pm
FS: 46mm manual trans throttle body mopar_man Classifieds: For Sale/Trade 1 11 Nov 2009 08:54 pm
FS 03 GT Manual Trans Throttle Body mvandale1 Classifieds: For Sale/Trade 0 18 Nov 2007 12:47 pm
