Dash indicator lights flash when driving
  • 1 Post By Deac1234
Old 31 Mar 2019, 05:47 pm
Default Dash indicator lights flash when driving
2006 GT turbo. When I'm driving all my dash indicator lights flash off and on, sometimes the motor will stall, when on the freeway it stalls then starts back up. Any ideas?
Old 31 Mar 2019, 06:02 pm
RickinPA's Avatar
Default Re: Dash indicator lights flash when driving
Sounds like an intermittent connection in the "run" circuit. Basically the same effect as turning the key off briefly then back on.
If it were mine, I'd dig out all the schematics for the "run" circuit and check the connections, connectors, wiring and switches.
Old 01 Apr 2019, 11:41 am
First time this happened to me it was the key switch. Electrical module on left side of steering wheel. next time it acts up while running push the key in and out if it stops it's probably the key switch or the part that connects the key tumbler to the key switch. both have a spring loaded plunger that are suspect.
Old 02 Apr 2019, 07:04 pm
Fixed mine.....
Might fix yours? Good luck.
Alfie1 likes this.
Old 04 Apr 2019, 12:55 pm
rsrocket1's Avatar
I think finding the proper replacement parts for the Gen2's is a lot harder than for the Gen1's.
Is there anyone with a Gen 2 who had this problem been able to find the replacement parts?
edit: Oops, it looks like the guy in the video is working on a Gen 2 PT. Are those funky vent controls exclusive to Gen2's?
2006 PT Cruiser check engine lights flash on then off weaselguys General PT Cruiser Discussions 7 08 Nov 2018 12:31 am
Dash lights come on, headlights flash , electrical surge?? Toolman General PT Cruiser Discussions 1 15 Oct 2016 10:32 am
Tail lights don't flash when opening doors remotely ceil99 General PT Cruiser Discussions 9 24 Apr 2016 01:32 pm
Instument panel loses power, then all lights flash??? Samson Tech & Performance Forum 22 15 Oct 2011 09:59 am
indicator and hazard lights jobaz General PT Cruiser Discussions 4 24 May 2010 12:28 pm
