Stage1 Sound Enhancement
  • 1 Post By NitroPT
Old 31 Mar 2019, 11:46 pm
Default Stage1 Sound Enhancement
With the Stage1 PCM installed, the car is noticeably louder.
Does anyone know how that is accomplished?
03 Turbo AutoStick
107K
Cranny
Old 01 Apr 2019, 01:37 am
podo2000's Avatar
Default Re: Stage1 Sound Enhancement
Didnt notice any significant loudness when I got my S1 done.
2004 PTGT 135Kmiles
Old 01 Apr 2019, 09:42 am
Really? Well its noticeable to me!
03 Turbo AutoStick
107K
Cranny
Old 01 Apr 2019, 10:21 am
Handy_Cruiser's Avatar
Never notice that. With my first one, I was hoping for a little turbo whistle. But the little toy turbocharger on these cars seems to be fairly quiet. Adding a cold air intake gives more engine sound. But nothing from the PCM tune as far as I've seen.
Old 01 Apr 2019, 10:23 am
I wonder if it's a combination of the S1 and the high flow air filter i have in it?
03 Turbo AutoStick
107K
Cranny
Old 01 Apr 2019, 10:54 am
Fk5 Fk5 is offline
You didn't do the MP BOV, did you?
2003 GT 5 speed
162,000 miles
Old 01 Apr 2019, 10:58 am
No I didn't.
03 Turbo AutoStick
107K
Cranny
Old 01 Apr 2019, 06:40 pm
_PTGT03's Avatar
unscientific claim. get a sound meter, do some tests and put this matter to rest.
Old 01 Apr 2019, 07:01 pm
There are several reason you may be experiencing louder exhaust noise.
The Turbo may be producing more and quicker boost pressure. You may be throttling harder. Depending on what when and where your ECU came from and what real changes were done, and your original ECU may not have all updates and the STAGE 1 may be introducing a richer mixer and advanced timing comparing your replaced ECU which can make exhaust sounds different then what you are use to?
Without looking at real data like AFR, timing,knock values etc., when you experience the louder noise it is going to be hard to support the STAGE 1 by itself and the programming makes enough difference over a stock ECU to influence enough of a sound change to be normally noticed.
BUT.. its your ride and only you know it best. So if you say it is louder now IT IS!
podo2000 likes this.
Old 01 Apr 2019, 08:40 pm
That kind of goes to my original question on what causes it. I'll do some comparisons.
Stand by.
03 Turbo AutoStick
107K
Cranny
How do I know If Im runing a Stage1 PCM? niel Stage Turbo Kits 17 15 Apr 2011 11:19 pm
03 vs 04 stage1 pcm Fuct Stage Turbo Kits 3 30 Sep 2010 10:24 am
15 psi. with stage1!!!! EDGAR TAMAYO Stage Turbo Kits 4 09 Jan 2005 10:55 pm
2.4HO & stage1 BACKinMOTION Stage Turbo Kits 23 09 Jun 2004 02:50 am
'04's Just PCM 4 Stage1??? knowyourturbo Stage Turbo Kits 1 27 Dec 2003 03:20 pm
