Sometimes it starts, sometimes not
Old 01 Apr 2019, 08:12 am
Exclamation Sometimes it starts, sometimes not
Hi,
Not sure to be on the right section of this Forum, let me know if not
I have since Friday a weird problem.
Friday morning, my car starts as usual. At the lunch time, it just didn't.
Everything looks right, but when I was turning completely the key, the car won't start at all, exactly as if I didn't put my foot on the clutch pedal.
Friday evening it starts, saturnday not, today it starts, half an hour after that I tried again and it didn't...
I have no clue on what is going on, I don't even understand the problem...
Any of you has a hin/clue/suggestion?
Thanks for your help!
PS: My car is a 04' convertible 2.4 atmo manual transmission
Old 01 Apr 2019, 04:13 pm
rcktpwrd's Avatar
Post Re: Sometimes it starts, sometimes not
When in the no start condition do you hear the fuel pump priming the system?
Is the engine cranking over and not firing or no crank at all?
Joel
www.rcktpwrd.com
Old 01 Apr 2019, 06:43 pm
_PTGT03's Avatar
Default Re: Sometimes it starts, sometimes not
Sometimes the contacts for the starting relay can work themselves loose. remove the fuse/relay box, push and squish on that relay and see if it makes a difference.
Old 01 Apr 2019, 09:07 pm
My first PT had random no cranks but would start only with jumper hooked to starter. Replaced the battery cables and 4 years later I never had a single issue. Well except when the auto shut down relay would intermittently fail causing the car to not start or it would shut the the engine down while driving.
2003 GT
Old 02 Apr 2019, 03:22 pm
Grounding wires. If only to cross it off the list.
starts but won't run after repairs Pineconepercy General PT Cruiser Discussions 33 18 Apr 2016 06:57 pm
Starts and stalls JHCruiser General PT Cruiser Discussions 4 06 Sep 2015 04:55 pm
engin runs rough at operating temp ,starts fine but starts to buck when you give it t moby General PT Cruiser Discussions 1 01 Oct 2014 06:57 pm
Car starts at second try...help please. jcmnz24 General PT Cruiser Discussions 13 15 Jun 2013 03:41 am
PT starts bad ProDigit General PT Cruiser Discussions 5 03 Nov 2010 02:23 pm
