How to fix wobbly manual trans shifter
  • 1 Post By RickinPA
Old 17 May 2019, 01:56 pm
Default How to fix wobbly manual trans shifter
The shifter in my GT 5 speed has become very wobbly. I changed the bushings on the cable ends and that fixed the excessive fore and aft play. When I am in any gear the shifter can be moved from side to side. There is at least an inch or 2 of sideways play. Miraculously it still shifts OK. Anyone know whats wrong with it?
Old 17 May 2019, 02:42 pm
rcktpwrd's Avatar
Cool Re: How to fix wobbly manual trans shifter
Did you change all four bushings?
Joel
www.rcktpwrd.com
Old 17 May 2019, 06:52 pm
Default Re: How to fix wobbly manual trans shifter
Yeah, that was my question too. I've had a couple of shifter bushing failures that left me without reverse, on the road. Fortunately, I was able to get the car home and replace the bad bushings. Check 'em all, don't let it strand you out on the road.
Old 17 May 2019, 06:59 pm
rcktpwrd's Avatar
I have the Booger bushings in mine and have had a couple of them break at different times. It still shifted OK but the shifter had lots of extra play...
Joel
www.rcktpwrd.com
Old 18 May 2019, 04:09 pm
The repair kit came with 2 bushings for the trans side and one for the shifter side. My play is side to side not front to back. So if it's in first gear the shifter moves side to side. Is there a other bushing in the shifter.
Old 18 May 2019, 04:37 pm
There are two cables. Each cable has a bushing at each end, four bushings total.
Two bushings are at the top of the transmission. You can see one bushing by looking down between the air box and engine. To see the other bushing you have to remove the air box. To replace it, you have to remove the air box bracket (if memory serves me correctly).
Two bushings are under the center console. To examine them you have to remove the center console. One bushing is on the passenger side. The other bushing is on the driver's side.
In general, if you own a manual transmission and you're going to keep it for a while, keep shifter spare bushings on hand. They may be considered a "wear item".
Old 14 Jun 2019, 10:29 pm
Ok I found out what the cause of the wobbly shifter was. It was a missing bushing at the transmission shifter cable that controls reverse. I had recently replaced these so I did not suspect that the new bushing would fail or fall out, but one did. Not sure if there is supposed to be a clip holding the cable on to the trans bracket but I don't have one. The shifter is a fairly complicated mechanism and I could not tell how it actually worked or why the loss of the reverse cable bushing affected the side to side play. If anyone can explain its operation it would be interesting. That's for the help.
Old 19 Jun 2019, 06:31 pm
Just my observation. One cable transmits the "X" position, the other cable transmits the "Y" position. Let's call them cable X and Y. Each cable has three settings: extended, midpoint, retracted.
Cable X transmits the following can be selected:
1, neutral, 2
or
3, neutral, 4
or
5, neutral, R
Which particular one of the above gear selection is transmitted depends on the setting of cable Y: extended, midpoint, retracted.
It seems like when one of the bushings goes, there's too much slop in the system to reach Reverse. Except if the cable falls out of place entirely, then the shifting is going to be all fouled up.
Hey! Who remembers when your three-on-the-tree got out of sorts and you had to go under the hood to straighten things out?
chuzz likes this.
manual trans. Jaredcruiser185 General PT Cruiser Discussions 3 11 Sep 2014 10:49 am
Trans Shifter doesn't lock into park jdr4170 General PT Cruiser Discussions 1 18 May 2013 07:40 am
Manual trans Cruser need help!! jrod1295 Tech & Performance Forum 1 18 May 2012 11:48 pm
manual trans noise wyok General PT Cruiser Discussions 2 12 Oct 2010 05:28 pm
Auto Trans shifter quit on me.... BumperBob Tech & Performance Forum 10 30 May 2007 06:27 am
