Multifunction Switch - High Beam position
Old 03 Jul 2019, 02:07 am
area49's Avatar
Default Multifunction Switch - High Beam position
Hello forum,
A few days ago, the fog lights on our PT were suddenly on, even though the switch was in the off position.
So, I took the multifunction switch apart and repaired it.
Now the fog lights and everything is working correctly, BUT (there is always a but, isn't there?) I cannot switch to high beam anymore.
Low beam and flash work fine.
I assume a piece has gotten moved out of place, but which one?
Anybody had the same problem? What am i missing? How did you solve it?
Greetz from across the big pond
Old 03 Jul 2019, 05:14 am
area49's Avatar
Default Re: Multifunction Switch - High Beam position
Just found the culprit, I was missing one little tiny plastic part and the room was vacuumed yesterday ... going through the dust bag I was able to retrieve it.
No low beam, strange high beam, multifunction okay? Prostheta Tech & Performance Forum 15 04 Nov 2018 12:31 pm
No High Beams or High Beam Indicator inertian General PT Cruiser Discussions 10 23 Jul 2016 04:26 pm
Multifunction Switch - Headlights not working - can I use switch with Fogs? bwiencek General PT Cruiser Discussions 1 13 Oct 2014 01:51 pm
Failed high-beam switch melted connector Nick_D Tech & Performance Forum 4 21 Jul 2014 08:53 am
Two Position to Four Position Power Window Switch axxsys General PT Cruiser Discussions 6 06 Dec 2008 10:29 pm
