Engine vibration at idle.
Old 04 Jul 2019, 07:43 pm
Default Engine vibration at idle.
Engine vibration at idle started after P0401
code came on second time. First time code came and
disappear,then second time it came back after about 3 months.
Decided to change EGR valve with modulator.
Since I was already under the hood, replaced
spark plugs gapped at 0.42 "champions", distributor, new wires,
throttle body cleaned new gasket installed,
pcv valve and hose, egr valve and modulator 2 new gaskets and rubber ring. all parts confirm oem
After all installed, started engine and noticed that before,
engine started immediately, now it takes two turns for engine
to start. Is it normal for engine to start on second
turn,rather then immediately?
Rpm steady.
No codes.
Vibration still there almost at the same level may.
What could be other causes of engine vibration?
I read forum posts on vibration causes,
engine mounts and timing belts seems to be
prevalent causes.
In my case timing belt was relapsed, this was verified
by service shop I took car in for inspection and head gasket
replacement.
Is there away to check motor mounts?
2002 PT LIMITED 93000 miles
Thank You.
Jack.
Vibration at Idle somerandomperson Tech & Performance Forum 10 15 Apr 2017 08:32 pm
Sorry, another idle vibration question... Gru General PT Cruiser Discussions 3 25 Feb 2015 07:49 pm
Idle vibration garner49 General Turbo Discussions 14 07 Apr 2013 09:48 pm
Idle vibration, Let me see of I have this right Gru General PT Cruiser Discussions 6 25 Mar 2013 03:56 am
Idle vibration... garner49 General Turbo Discussions 6 17 Nov 2009 06:40 pm
