high beams won't turn off
Like Tree6Likes
  • 2 Post By _PTGT03
  • 2 Post By RickinPA
  • 2 Post By Ornald
Old 08 Jul 2019, 12:45 am
Default high beams won't turn off
Greetings. Hopped in to my 2003 touring today to do errand. Turned on headlights as I do whenever I drive. I noticed the high beam indicator on (replaced all instrument cluster bulbs few weeks ago when one burned out); when I clicked the lever to return to low beam, nothing happened. High beam indicator on dash still showing. I got out and checked headlights; parking, low and high beam all on.Only way to turn off high beam/low beam (and be able to engage fog lamps) was to switch to parking light setting only. Was about to order replacement multi function switch but thought I'd check with you guys first. Any advice would be appreciated. I am not voltage/circuit tracing type. Thanks.
Old 08 Jul 2019, 01:56 am
Default Re: high beams won't turn off
I would suggest checking the headlight relay first.
Old 08 Jul 2019, 02:01 am
_PTGT03's Avatar
multi function switch going out ! replace it, cheap part and it's probably worn out if original
Old 08 Jul 2019, 12:00 pm
Multi-function switch is the usual suspect. My 2001 is on its second replacement. IMO they route too much power through the switch for the headlights and fog lights. The connector gets "crispy" too.
Old 08 Jul 2019, 05:12 pm
Thank you PT Cruiser Steve, PTGT 03(love that green, rare around here), and RickinPA! I think I will order relay and multi switch; if relay works(x fingers) can return other. If not will be in possession of plan B. Multi switch is probably original; bought silver cruiser used here in Northern Virginia(originally came from Rhode Island) after my Black 2001 LTD hit mini van broadside (it pulled left turn through stopped traffic right in front of me). 'bye, 'bye PT! Well, time to order parts. Thanks, again!
No High Beams or High Beam Indicator inertian General PT Cruiser Discussions 10 23 Jul 2016 04:26 pm
Turn signal / high beam / fog light stem 2BadRic Exterior Accessories Forum 2 21 Mar 2013 10:24 am
Stuck on high beams Agnav General PT Cruiser Discussions 2 08 Jun 2011 08:02 am
High Beams Stopper Working reh8388 General PT Cruiser Discussions 3 25 Aug 2010 07:30 am
Low Beams and High Beams jingks Exterior & Interior Styling 3 24 Jan 2008 03:16 pm
