working around the radiator
Like Tree4Likes
  • 4 Post By RickinPA
Old 24 Jul 2019, 08:42 am
RickinPA's Avatar
Default working around the radiator
Not PT specific, but it could apply.
Replacing a fan assembly in a Neon, I came too close to punching a hole in one of the radiator tubes. Fortunately, I only smashed some fins. This occurred while I was pulling out the fan assembly. The manual says to "carefully remove the fan assembly", you can't. There's always a bunch of hoses, wiring, bad pull angles and whatnot that want to push the fan assembly into the radiator.
Before I put the new fan assembly in, I cut a piece of cardboard to fit between the fan assembly and radiator. That seemed to do the trick as I was able to get the fan assembly back in without damaging the radiator core. It was a bit ticklish to remove the cardboard once the fan was in, but worth the effort.
If I did the job again, I'd slip some cardboard between the fan assembly and radiator before attempting to remove it.
Anyway, just thought I'd share.
Carl48, Fk5, Cat22 and 1 others like this.
Old 24 Jul 2019, 11:46 am
Fk5 Fk5 is offline
Default Re: working around the radiator
I hear people complain about this issue and wonder why it was so easy for me. Then I remember that I removed the intake to swap the gaskets at the same time that I did mine. Much more room that way! I still managed to snap my dipstick, but that is another story!
2003 GT 5 speed
162,000 miles
Old 24 Jul 2019, 05:38 pm
Removing the battery and battery support plate made it much easier to replace my radiator fan on both of my Pt Cruisers.
A/C and Radiator fan not working. lenwood Tech & Performance Forum 2 11 Aug 2014 02:25 pm
Radiator fan not working tri5fan Tech & Performance Forum 8 01 Jul 2012 11:29 pm
01 pt cruiser radiator fan not working HELP salteedogg Tech & Performance Forum 14 18 Mar 2012 03:47 pm
Radiator fan not working! HELP Zerotolerancecustoms General PT Cruiser Discussions 2 20 Feb 2012 09:19 am
HELP!!!: radiator fan not working... him72787 Tech & Performance Forum 10 17 Jun 2011 09:21 pm
