P0463 after Timing Belt job
Old 27 Jul 2019, 09:20 am
Default P0463 after Timing Belt job
Hi All, did a timing belt kit yesterday and I assume with all the engine jacking up and down I affected a harness or connector as I now have a "Fuel Level Sensor A high" error. First noticed the gauge read full, I knew there was no way my daughter filled her tank, then watched it go to empty, full again, now it's just empty with CEL on soon as ignition turned to on. I found a fuel diagram but have no idea where these connectors, C110 C104 or the grounds are to start a search. In the meantime I'll find someone to watch the gauge while I wiggle suspect harness's underhood.
Thanks for any pointers
Mike
Old 27 Jul 2019, 10:43 am
RickinPA's Avatar
Default Re: P0463 after Timing Belt job
C104 should be a dark gray connector, 14 pins, on the front side of the automatic transmission, in a cluster of three connectors, the one closest to the passenger side.
C110 should be (color not specified), 10 pin connector, on the frame in the engine compartment, well below the passenger side McPherson strut mount, down where the frame turns horizontal.
The fuel level sensor signal appears to go through connectors C106, C110 and C304. C106 is in left side of instrument panel, C304 is at fuel tank. So if it were me, I'd focus on C110, and that's down where the timing belt work would have been done.
Information from a 2001 PT Cruiser Service Manual.
Old 27 Jul 2019, 01:29 pm
Beautiful! Thanks so very much for this.
I never said it first post, it's a 2007 non-turbo automatic.
having a hard time with the timing belt and the timing marks need help mr42ndstblvd Tech & Performance Forum 3 04 Apr 2018 06:15 pm
2006 Timing Belt, Belt to tight, Won't fit over engine ajhockey3 General PT Cruiser Discussions 34 17 Nov 2017 11:17 am
2007 PT Cruiser: OBD Codes: P0700, P0750, and P0463 Topgear Tech & Performance Forum 5 17 Jun 2007 05:07 pm
