Where is the oli pressure sensor (2002)
Like Tree2Likes
  • 1 Post By RickinPA
  • 1 Post By Macgyverman1123
Old 15 Aug 2019, 06:51 pm
RVC RVC is offline
Default Where is the oli pressure sensor (2002)
My oil pressure light recently started coming on briefly. Checked the oil and it's fine. I figure the oil pump can't be going bad so the only thing left is the sensor which I guess I'll need to replace. Question is where is it? Thanks.
RVC
2002 2.4L Woody Normally aspirated
Purchased 2/29/16 w/ 104,048 miles
Old 15 Aug 2019, 07:16 pm
LionPT's Avatar
Default Re: Where is the oli pressure sensor (2002)
It located at the back of the engine towards the middle drivers side.
Either way from top or bottom, you can't see the whole thing...lol
I've replaced from both & found the top much easier...just remove air cleaner assembly & tube (unplugged MAF sensor).
Drain the oil 1st or your in for a messy job.
Old 15 Aug 2019, 08:08 pm
Handy_Cruiser's Avatar
It's best accessed from beneath the car but you can get too it from the top. It may have a foil cloth cover over it. Here's mine before I changed it out. That aluminum piece you see on the left is the transmission. So it's almost at the left end of the block on the back side.
Old 15 Aug 2019, 08:10 pm
Here's some reading:
Spurious oil light... how hard is it to change the sensor??
HOW TO: oil pressure sensor replacement
what's inside that oil pressure switch?
Oil Pressure Sender/Sensor Info
As I remember, the connector can be a bugger to unlatch, especially if you can't see it (if it's turned away from you) and have to work by feel.
OldMiner likes this.
Old 16 Aug 2019, 11:06 am
RVC RVC is offline
Thanks, guys! I'd probably still be looking for it.
It's good to be back on this forum.
RVC
Old 16 Aug 2019, 05:54 pm
Macgyverman1123's Avatar
Mine wasn't bad when I changed it, just leaking (And spraying onto the manifold). My tip: Spray it off with Brake Cleaner before you start for an easier time gripping it.
chuzz likes this.
-John P.
Go Canes! #TakeWarning
Install - Oil Pressure Sensor geronimo Tech & Performance Forum 27 02 Feb 2015 04:31 pm
Oil Pressure Sensor ???? nonstopgo68 Tech & Performance Forum 6 30 Jun 2014 08:43 pm
Oil pressure sensor: OEM or aftermarket? Strilla Tech & Performance Forum 12 13 Apr 2013 11:31 am
Oil Pressure Sensor Questions 03silvergt Tech & Performance Forum 7 05 Nov 2012 06:02 pm
releasing the oil pressure sensor geronimo General PT Cruiser Discussions 0 29 Mar 2010 03:31 pm
