Belt Rubbed thru the Oil Pan
Like Tree4Likes
  • 2 Post By Busted_PT
  • 1 Post By Handy_Cruiser
  • 1 Post By soonercruiser
Old 24 Aug 2019, 08:35 pm
Default Belt Rubbed thru the Oil Pan
I was talking with a gentleman the other day who had an interesting oil leak. Seems the timing belt was "walking" and wore a small hole into the side of the oil pan.
I'd not heard of this happening and thought it might be a good heads-up for those diving into a belt change procedure.
He described the belt as being frayed along the near side when removed. Mileage on the belt was unknown but the car was showing around 220k miles at the time. (See other thread for belt fraying question.)
His solution was to drill a small hole at the leak site and tap in a small screw. I'd have probably replaced the pan, but he saw his fix as a win.
Bob in Liberty MO
Old 01 Sep 2019, 02:12 am
Default Re: Belt Rubbed thru the Oil Pan
Bob in Liberty MO
That hole has to be in the oil pump. No part of the oil pan are close enough for that.😎
Old 01 Sep 2019, 09:03 am
Handy_Cruiser's Avatar
Like Danny says, it was likely the oil pump/front cover and not the oil pan.
Old 01 Sep 2019, 12:34 pm
soonercruiser's Avatar
Red face Re: Belt Rubbed thru the Oil Pan
"Screw into the oil pump"???
Ignorance is bliss, if it works!
Frank, aka SOONERCRUISER,
Old 27 Dec 2019, 05:47 pm
Earlier today I posted that I'd identified the source of my persistent oil leak. Seems it was a rub-through leak on the oil pump housing not unlike that tolds to me in this thread.
I'd have to wonder what would cause a belt to walk and rub in the first place...and if the rub would cause a discernable sound, indicating impending failure.
Bob in Liberty
2006 Timing Belt, Belt to tight, Won't fit over engine ajhockey3 General PT Cruiser Discussions 34 17 Nov 2017 11:17 am
Manual timing belt tensioner vs auto belt tensioner Bandit2014 Tech & Performance Forum 9 11 May 2016 01:57 pm
Timing belt shield, belt replacement. jdwalk04 Tech & Performance Forum 13 14 May 2012 10:01 am
Belt chirp even with new belt and tensioner imalittleturt Tech & Performance Forum 5 22 Jan 2012 10:31 pm
Belt change help - Not timing belt skfloyd Tech & Performance Forum 2 23 Apr 2010 11:23 am
