Missing really bad
Like Tree8Likes
Old 07 Sep 2019, 10:41 am
markeele's Avatar
Default Missing really bad
Okay I have a cylinder 1 misfire I have new plugs new wires new coil new cam position sensor and still a bad misfire so at this point do I assume that it is fuel-related and that maybe I have a bad fuel injector or what's the advice on where to go from here any help would be greatly appreciated thanks
Old 07 Sep 2019, 10:51 am
Default Re: Missing really bad
These cars tend to be very fussy with aftermarket coils. Even brand new ones will often not work correctly right out of the box and the problem is still there. To rule this out, you can go to any junkyard and buy a used coil from any PT or Neon and try it. It may very well solve your problem.
Old 07 Sep 2019, 12:43 pm
There are technically 2 coils in the coil unit so unless you have a continuity at the terminal you would have 2 cylinder misfire DTCs of problems on one side of the coil.
markeele likes this.
Old 07 Sep 2019, 02:55 pm
_PTGT03's Avatar
It's a common issue on these cars for the last foot of the wiring harness from the coil connector wears out internally and encounters high resistance only under load so it's not something that can show up on a resistance test. A common sense first troubleshooting step is to perform a resistance test from each pin on the coil connector to its corresponding connector and pin once disconnected from the ECM.
There's also pre-fabricated connector and tail repair kits sold on ebay and other stores since this can be a common issue with the SRT-4 engines and PT cruiser engines.
I had this exact problem before and since then have solved it.
Old 07 Sep 2019, 03:18 pm
True, but when my coil went bad, I only had one cylinder misfire code and not two. A replacement coil from my local U-pull yard solved the issue.
Before I started replacing connectors, I would try a coil. It may not be the case for your car, but it is a fairly common failure now that these cars are getting old and higher mileage. I have helped several in the past and while it could be other things, such as bad wiring as suggested, or even a PCM failure, usually it is the coil.
Old 07 Sep 2019, 04:09 pm
If you look at the electric schematic of how theses coil pack work then it is very hard to consider how this could happen unless there was a terminal problem?
The PT cruiser is a waste spark ignition system please think about that before you answer.
I do understand that at times simply the replacement of a part new or used at times the act of movement can sometimes cure the problem by establishing a lost continuity.
This guys issue I can almost grantee is not a coil....but then I would be guessing in which a guess (estimate or suppose (something) without sufficient information to be sure of being correct) is something I truly dislike members on forum to do. LOL
IMHO this guy should really spend less time on the coil and to do more diagnostic checking of other things including the fuel injectors and compression of the cylinder.
Old 07 Sep 2019, 05:59 pm
markeele's Avatar
Maybe a little more info would help, it seems to run fine as long as im on the gas but as soon as i let off it starts stumbling and missing. Which is why im thinking maybe fuel, thanks for the advice so far,
Old 07 Sep 2019, 07:02 pm
Intake gaskets good?:
Old 07 Sep 2019, 07:13 pm
markeele's Avatar
Yes replaced about 6 months ago
Old 08 Sep 2019, 10:01 am
PTSantaCruz's Avatar
I had the same thing and was told it was my coil. I changed it with a new one and the problem went away , for a few minutes then returned . hahaha! After which I spent a couple weeks buying all the tune up parts and old hoses trying to fix the misfire. Finally I read here on this forum in another thread somewhere about swapping the fuel injectors from another working cylinder in the engine. When I did that the misfire went to the cylinder with the questionable fuel injector. So bought one new fuel injectors and the problem was gone.
Life is a Gas and we need to keep fueled up!
PT missing Csmith General PT Cruiser Discussions 6 08 May 2016 07:13 am
What am I missing? Jacob Tech & Performance Forum 0 04 Aug 2011 09:12 am
Am I missing a fuse? purple people eater PT Cruiser Convertible Forum 1 20 Jun 2009 07:37 pm
The missing key careyk General PT Cruiser Discussions 3 09 Apr 2009 02:33 pm
MISSING AGAIN/HELP kromans Turbo Performance 8 24 Jan 2005 11:59 am
