New Project '03 MT Cruiser Rod Knock
Like Tree4Likes
  • 4 Post By Mealticket
Old 08 Sep 2019, 08:37 am
Default New Project '03 MT Cruiser Rod Knock
All - just brought home a project, previous owner ran it out of oil resulting in rod knock. 5 spd MT, barely got it home because it was bucking and lugging badly in 1st and 2nd. It liked 3rd much better so I used 3rd to nurse it home. It has P0344, cam position sensor, so I hope the bucking is related to that.
Will most likely grab a used engine out of a wreck to get this gem back on the road. It was well cared for and pretty clean, 140K miles on the clock. Should be a fun project. I'll post up progress.
MT
Old 08 Sep 2019, 09:25 am
Default Re: New Project '03 MT Cruiser Rod Knock
> PICTURES<
Old 09 Sep 2019, 03:50 pm
Fk5 Fk5 is offline
MT
When the cam position sensor goes out, the limp home has an rpm cutout. That is probably why it preferred 3rd. I can't remember where mine started breaking up, but it was probably around 2500 rpm. Change that and it will probably be okay to drive around. I think mine cost $15 and it is pretty easy. Don't overtighten it or you might crack the magnet and check that the issue isn't the connector.
2003 GT 5 speed
162,000 miles
Old 09 Sep 2019, 07:44 pm
_PTGT03's Avatar
rod knock is easy to determine as it increases in intensity with engine load and rpm/.
coincidentally, ran my pt low on oil, did some high speed turns and lost oil pressure - just enough to damage the connecting rod bearing but not register as a warning on the oil pressure gauge even.
Old 19 Sep 2019, 09:49 am
Took some pix of the exterior. Interior is nice. I think I have an engine identified at the yard, and will pull the AT with it since I work on those anyway. I'm not great at file sharing sites so please excuse the images size.
MT
Old 26 Sep 2019, 07:24 pm
Yikes, my pix rendered blurry and nasty. Anyway, installed powertrain Monday, fired it up yesterday (Wed) and got OBD monitors to run during simulated driving with drive wheels still off ground, smogged it today, and got tags at DMV. I couldn't get the lower torque strut to even install; the front mount bolt at the PS/AC bracket wouldn't line up. Looking at the FSM, I now see why. I didn't give any thought at all to the upper/lower torque strut adjustment. I will need to do that, as going without the lower one installed made for some very nasty effects on my short drive to the smog shop. Kind of fun shifting those 5 gears on my drive,
MT
pt cruiser project kuli Europe PT Forum 6 07 Nov 2013 12:25 am
2002 PT Cruiser 2.4L Project asa323 Members PT Project 8 21 Aug 2013 04:08 pm
Hybrid PT Cruiser Project Knightwolf Members PT Project 16 20 Jun 2013 07:08 am
my pt cruiser project :) Garya1682 Members PT Project 7 15 May 2013 06:11 am
knock sound in front pass wheel well, 01 pt cruiser sickened1 Wheels, Tires, Suspension 8 02 Oct 2009 02:56 pm
