04 stumbles @ hard acceleration
Like Tree9Likes
  • 2 Post By Espresso
  • 5 Post By circus
  • 2 Post By circus
Old 14 Sep 2019, 10:25 am
Default 04 stumbles @ hard acceleration
I apologize for asking if redundant. Hoping to avoid throwing parts at it.
The car: 04 Cruiser, non-turbo, >200k miles, standard trany, newish plugs, injectors cleaned, shows catalyst code.
The symptoms: Runs great when cold but once warm it stumbles at full throttle. Accelerates fine at partial throttle. Really apparent if I use the resume button on the cruise control.
Old 14 Sep 2019, 01:24 pm
_PTGT03's Avatar
Default Re: 04 stumbles @ hard acceleration
disconnect your O2 sensors and drive to see if symptoms remain
Old 14 Sep 2019, 03:28 pm
No change. If anything worse. Fine cold. Warm at full throttle it's stumbles using two cylinders instead of all four.
Old 14 Sep 2019, 08:11 pm
_PTGT03's Avatar
With a cold engine, take a heat-gun point it at the ignition coil until it's reasonably HOT.
Drive around and see if theres a difference.
Could be the issue.
Keep elimination of controls and sensors in mind so you can effectively troubleshoot intelligently.
O2 sensor
ignition coil
ignition wires
wiring to the ignition coil
throttle position sensor
MAP sensor
fuel pressure variations
etcetera
Old 15 Sep 2019, 01:16 am
I'll evaluate the engine's condition considering the mileage and the fact that the prior owner (girl) probably ignored problems til it wouldn't move anymore.
Old 15 Sep 2019, 01:28 pm
need a real time scanner. could be either weak spark getting blown outby weak ignition or cylinder blowby.
or just a weak fuel pump, bad filter or regulator.
its one of the easiest things to diag. do a cyl leakdown test first, then diag the ignition and fuel. ignition is easiest as a coil, plugs and wires are less than $100.
_PTGT03 and circus like this.
2003 GT
Old 15 Sep 2019, 01:29 pm
to note. I would recommend to do a pull hit the stumble, pull over and shut it off then pull each plug and check them. But its kinda difficult with the intake manifold setup.
2003 GT
Old 28 Jan 2020, 06:19 pm
Fixed. Bad injector. Problem was it wasn't bad enough to be obvious.
Old 27 Feb 2020, 10:23 am
Update: Also fixed the occasional P0420 (catalysis)
Updated update: Never mind, P0420 just came on
Handy_Cruiser and chuzz like this.
Stumbles out of 2nd when stopping MarriedToIt Tech & Performance Forum 10 22 Nov 2015 08:18 pm
Noise On Hard Acceleration djrandyran Tech & Performance Forum 15 21 Jul 2014 05:42 pm
2002 PT stumbles at speed - thx for any help BlueInGA Tech & Performance Forum 3 25 May 2012 03:00 pm
2005 PPT Cruiser Still Stumbles after lots of work done. qcruiser Tech & Performance Forum 8 12 Jul 2011 08:56 pm
01' PT stumbles, barely runs jarvisxl Tech & Performance Forum 2 23 Jun 2011 06:14 am
