Trick I used for Engine Install '03
Like Tree6Likes
  • 6 Post By Mealticket
Old 23 Sep 2019, 09:36 pm
Default Trick I used for Engine Install '03
All - I am working alone on a dirt surface, and I weigh all of about a buck fifty...so since I was having trouble dropping the 2.4 in I resorted to trickery. I could roughly line up the pass side middle mount bolt but couldn't easily move the engine over close enough to start the bolt, so I went to the nearest Ace hardware and got a long 12M x 1.75 threaded stock, a nut for it, and washers to step up from the size of the nut to the size of the access hole. I screwed the threaded stock into the mount through the access hole, then put the washers and nut on from the wheel well, then tightened the nut and drew the engine on that way. I installed the tranny separately. I have been using a similar method to install trannies to engines for years,
MT
Old 24 Sep 2019, 07:43 am
Default Re: Trick I used for Engine Install '03
Necessity is the mother of invention.
Water pump trick Helirich General PT Cruiser Discussions 20 18 Dec 2015 12:31 am
What's the trick to getting an A/C compressor out? ProntoCruiser Tech & Performance Forum 4 06 Aug 2014 03:48 am
Neat trick Vlefaive Tech & Performance Forum 4 22 Jun 2012 07:36 pm
Need to share a new trick turbomangt The Detail Shop 8 19 Apr 2005 05:24 pm
Cheap Cooling Trick macster Turbo Performance 12 03 May 2003 12:13 pm
