Codes 522 and110c
Like Tree2Likes
  • 1 Post By ptcruisersteve
Old 10 Oct 2019, 09:07 am
Thumbs down Codes 522 and110c
Well car doesn't even have 87k...It was leaking tiny amounts of oil and only showing the 522 code .so when shop did timing belt I had them replace sensor..Didn't help..Is there a way to mechanically check oil pressure?? Being as I can't see or get to sensor I can't myself ,but a shop should be able to thread a hose and dial gauge with needle to check right??.I can believe its my oil pump with so low miles...Then onto the 110c from what I have checked its either bad module or open circuit between bcm and pcm..Which can't be tested by back probing or damage may occur..So a special tool or something is needed??? Am I gonna have to go to dealership or is this tool at most shops?? Thanks..Can't believe either is anything but wiring issue..If my oil pump is going at 87k that's messed up..What's the average cost oil pump replace?? Just spent 1200 on timing belt kit,new oil sensor and brakes..So funds low...Thanks for any replies..
first 4 cylinder,it sure aint no 8....2004 2.4 base pt 5 speed manual.live wires,screeming demon coil, stage 1jet chip,strut tower bar,airraid setup..nothing fancy...NO TURBO
Old 10 Oct 2019, 09:13 am
Default Re: Codes 522 and110c
There are several threads regarding the manually hooking up the oil pressure guage. If I have time later I will try to find them for you.
3rcruiser likes this.
Old 10 Oct 2019, 09:16 am
On your 110c I get that code all the time. In my Pt Cruiser the problem appears to be the PCM but keep in my Pt Cruiser is 2nd Generaton. 2007 Pt Cruiser.
Old 10 Oct 2019, 09:25 am
Thanks,it kills me thinking I am wiping out my bearings/engine slowly..I changed oil regularly and used Lucas additive.. I have never seen an oil pump go at 87k..So I am praying..
Old 11 Oct 2019, 05:52 pm
Well at least I know pressure can be tested with guage but can't find any posts..Used to be simple remove sensor thread hose with guage on and run car..Classics were much easier to work on,what you save in gas now you loose on repairs IMHO!!.. Looking for a classic car again..Thanks
Old 11 Oct 2019, 05:55 pm
I looked and haven't found any posts on it but my phone ain't so good....Thanksh
Help with codes KamloopsCruiser General PT Cruiser Discussions 8 13 Oct 2016 09:05 am
Dash codes--not the usual OBD codes--help! chitowncruiser General PT Cruiser Discussions 5 01 Mar 2013 11:56 pm
Codes, codes, codes... Desperately need engine light help... cdc3jj General PT Cruiser Discussions 9 01 Sep 2012 07:52 am
CODES codes codes... Anyone know what these codes may mean are wrong? rksnow1 Tech & Performance Forum 10 16 Jun 2012 11:06 pm
04 PT CODES?? NEW PC.. drumrooster Tech & Performance Forum 3 06 Aug 2011 04:35 pm
